drive line????
no im not 13 im actually 20. I like doing stuff just to say I did it even tho I didn't need it haha
great, that means you had one or two lessons of decency already,
one way or another ;)
The essence of my previous post remains untouched:
a) stay safe!
b) it'll be expensive.
So I still think it'd be a better idea to see what a governor removal and high flow in/out can do for you,
and then google around for performance parts.
billet flywheel & conrods first, valve springs stuff like that.
coryjage13
So what are you going to do...
Dont leave us hanging....
well depending how it all goes together when I get the frame built it will either be the RAGB connected to motor than clutch ran back to the axle or clutch on motor chain ran down a few inches to the RAGB and than from that to the axle
Hm, I think Tony's first suggestion is what will be the best possible solution here atm.
Engine->clutch->chain-> turning shaft-> RAGB-> chain ->Rear axle
the second option has the RAGB on the front of the kart, from there you would need a really long chain to get to the rear axle, and in between quite a handfull of idlers to keep it where you want it.
with a turning shaft, you don't have to worry about that.
firemanjim
Just kartin' around....
Houston Texas
Gotta go Engine/clutch, to sprocket on shaft. Shaft turns the RGB in back, which spins the axle via another sprocket/chain..... :thumbsup:
that's what I said, yes.
well I didn't mentioned the sprockets, since I thought mentioning the chain would imply the use of sprockets ;)
Well, that's how I understood what Tony suggested a few posts back.
And thinking about it, it's way more reliable than adding the RAGB to the clucth and driving a chain all the way from the front to the back of the kart.
And it seems to be cheaper than to find a cardan shaft which actually is the same setup but without a chain and sprockets..
(but with gears instead)
