Axle Problems Murray
JakeAxion
BIG MO
So whats going on is that i just bought a murray explorer and the back axle was bent. i can not get the tires off. They are rusted on. Any ideas on how to get them off would be wonderful. I would also like to know what size axle i should get. I don't know what size to get because the previous owners have not given me the manual.
JakeAxion
BIG MO
I dont know how to do pictures....
and i cant measure accurately with the wheels on and since its bent.
What do you mean by the axle should be vertical??
I currently have the back axle off its just the wheels that will not come off.
That makes it easier; stand the axle up so one wheel is resting on its side wall, spray the outside of the upper hub & the inside of the lower hub, leave it for 24 hours then flip it & repeat...
Still not coming off. should i take it to a metal press and just pay to get it off?
Maybe.....can you post up some pictures first? Sometimes we can see little things that may not be obvious to you and are invisible to us without them......
Btw- I have a solution If we don't see something in the pics .....
JakeAxion
BIG MO
I Have tried every thing. i got a metal press and a torch and tried to get it off that way, i have tried pb blaster. right now what i am doing is trying hydrochloric acid (HCl) and soaking it in. Does any one have any other ideas???
