Not happy with predator 212
ML-TOYS
long island, new york
As some of you know i put my new motor on my snowblower and i gotta say blahhhhh.
The tecumseh that was on it was an animal compared to this thing.
I use to throw snow 15 feet now lucky if it throws it 5 and never use to clog the output chute either like now.
Guess its time to get a new carb and starter for the old motor.
Half-breeder
"Edit" button removed
Rpms are not raise by a screw... Rpms can only be raised over 3600, by removing/bypassing, the governor... which is inside the case/block.
... BTW, did you do the 'break-in' period stage?
I must disagree wholeheartedly, with much experience. The stop screw located behind the manual throttle control on these (and many other engines) alters the governor set point. You most certainly can affect maximum RPM in this manner.
Absolutely- the governor only controls linkage- it can always be diasabled outside of the engine.
Half-breeder
not trying to argue... just trying to understand...
So your saying that even though the MAX rpm on clones is stated as 3600(w/ governor... as are most all motors from what I understand)... there is a factory 'screw', that allows it to exceed the 3600rpm mark?!? According to everything Ive read and calculated, Ive never been able to exceed the 3600 rpm mark on my HF212(and i even took the screw out). And ive calculated my speed according to the 3600 mark... and did exactly what the calculations said...(except that one time in Narnia...).
Just wondering what 'else' was done other than just backing out the screw("I" removed mine on my clone day 1...after the break-in... and it stayed maxed out at 3600)... Im just saying...:huh:
Half-breeder
....AAAHHHHHhh.... w/ bypass of the governor... makes sense now... didnt see anyone state the "bypassing the governor" clause...
Half-Breeder-
Without getting into a long winded thing, the purpose of the screw is to fine-tune the maximum governed RPM for the application. The engine is set up from the factory with it's springs and linkages, but how do we get it to exactly 3600 before shipping it out? Adjust the screw. How would one slow the engine down for a 3200RPM implement? The screw.
What needs to be pointed out here is the fact that the hand throttle does NOTHING aside from altering the spring tension in the governor system. By adjusting the screw, you are fine tuning the spring tension in the system.
The screw is basically intended to set the engine once when new, and a fine adjust after service or rebuild, but we enjoy the fact that it's there. On other types of engines, this very same spring tension is altered by putting one end of a spring in a different hole, or by bending the metal tang that the spring anchors to. Hope that helps.
As a reference, have a good look at any of your engines. You will note that there is NO direct mechanical link between the factory hand throttle, and the carburetor.
EDIT_ I never "bypass" a governor. Too risky. Been there, done that, learned the lesson.
Yes- and not limited to "bypassing" but by altering linkage lengths spring tensions, lever positions, ect....adjusted to different rpms... You're a smart fella- I'm sure you got it now.....
