Kx60 shifter kart
Jclark
Ok I found a piston and mount and all that's left is the radiator
Do you guys think one of the two radiators from the bike is enough to cool the motor
Tig
NC
It should be.
Check eBay, look around for shifter kart specific radiators, they go for pretty short money.
Jclark
Hey I read online that a lot of people plug the hpp valves on the shifter motors to get better top end
Would you guys know anything about that and would it be a good idea to do it
Jclark
There is a small hole on the top of the crankcase and I have no idea what it's for. It was meant to be there because there's a small rubber grommet around it, any of you guys know what this could be for. I'm leading toward it being a breather line that just doesn't have a hose but I could be wrong.
Jclark
I don't know how to post a picture but it is right under the rubber intake piece that the carb clamps into an it just has a little rubber grommet in it
Jclark
Ok I read through it and got the app and I still can't figure it out. Im terrible with technology. I can send it by text or email if any one wants to post there number or email.
Jclark
Also when the cylinder is off and the little piece that slides the rack in bottom of the cylinder for the power valves, how is that piece supposed to feel.
When I spin it clockwise it stops when the pin is facing down like at 270 degrees on a coordinate plane and if I spin it counter clockwise it stops when the pin faces directly up like at 90 degrees on the coordinate plane.
Is that how it should be.
cylinder off?
cylinder head off?
cylinder head cover (aka valve cover) off???
I think the last,
Are you talking about the rocker arms?
Wait.. still the cr250 engine? that's a two stroke, there are no valves...
:useless:
Sorry..
Jclark
Yeah I'm talking about the power valves on the cr250
And the whole cylinder is off
