Valves were approx 9 and 10 thou and now they are 2 and 3 and the performance is the same
One other thing, after running wide open for a bit and then let to idle and the shut off it back fires.
No oil when purchased. The first fill was with cheap 10W-30 for an hour or so and then I switch to 100% synthetic 10W-30 and have changed it twice . As for cross hatch I didn't really look for that, I just rubbed my finger all around with the piston all the way down and it was very, very smooth.
Put a tiny thin smear of lapping paste on the valve seating surface, drop the valve into place & apply a bit of pressure (as much as the spring would provide). Now use a sharpie or similar & place a reference mark on the valve & head.
Lift the valve & check the seat; wherever there's lapping paste on the seat, it sealed; if there is a void in the paste, well, I think you can figure it out...
Sorry- but WHY? The OP has already stated he was going to lap the valves- the very best way to determine valve seat. The only merit I see is possibly to determine a bent valve. ....Is that it?
I just did a leak down test and am showing approx 10% leakage and the air is coming back up through the carb.
Op stated
That means the inlet valve is not sealing; why not? It's a new engine...
Lapping the valves won't show anything, only that one point of the valve is contacting the seat at one point..
To answer you question simply, yes, that test shows if a valve is bent or possibly burnt
This is going to drive me crazy, I just got everything back together, leakdown is much better, only around 4% BUT it is even slower now than before 13mph. Where as it was getting 20 when the engine was new 10 hours of use before. It just feels like the throttle is not opening all the way or something. I varified that the butterfly inside is opening fully when the hand throttle is depressed. It idles perfect. I also took out the valve spring shims and set valves to 0.004"in and 0.006"ex. I tried going WOT and slowly pulling out choke it just gets worse, tried removing air cleaner all together and no change. Any other ideas.
