cracked carb boot
dictionary6767
Nj
the carb boot on my 2003 Yamaha warrior is cracked. would that cause it to run only on full choke? Im trying to see if I should order a new carb boot and a carb rebuild or just boot. it is pretty badly cracked like you can hear the air leaking.
exenos
Project Nut
That would do it. Try taping up the crack with electrical tape to see if it helps, if it does then you probably just need the carb boot.
fowler
Bullsbrook West Aus
Even if it's not an issue, it needs fixing as the engine is drawing in dirty air
But it will be causing the problem
When did u last clean the carb
While the carb is out u may as well strip it and clean it
So get the boot and gasket kit
Are there pieces missing in the crack? If so, might be able to put a patch over the hole, or if not just put some JBweld on the crack to seal the joint.
buckwheat
Lilburn, GA
If the piece is rubber or plastic try RTV silicone. Permatex makes several types depending on the application. Check to see which one is compatible with gas. Another thought....use a hot melt glue gun to run a bead across the crack.
machinist@large
West Michigan, 49331
Ill try the jb weld or rtv tomorrow. It's worth a shot since the boots is $35.
Try the electrical tape first; without knowing just what the parent material of the boot is, you can't just throw JB Weld, hot melt glue, etc. at it. With the tape, as long as you don't over heat it, or run it to long (like months) you should be able to remove it with minimal residue.
I would be reading some labels for the different grades of automotive Permatex and/ or Loctite gasket materials; I know that they most likely have just the thing for your problem. Without more detailed information though, it's kind of hard to recommend something specific....
fowler
Bullsbrook West Aus
It's not a perminent fix and very risky
U are aware if the jb weld gets inside the engine then it's at least minor damage if not game over
If u can't afford $35 now for a new boot then u certainly can't afford a few hundred down the track for a new head and bore
