Just found this forum hope can get a answer here others have let me down.
I cant seem to figure out or find out what the thread pattern is on the jets for a Honda GX200. Want to make a jet block for spare jets. Thanks for your time and knowledge.
I can't give you a direct answer for that but I may be able to solve your problem. Many places that sell hardware have an aluminum or plastic plate hanging of the rack to check bolt threads. Just screw the jet in......
If you have a tap and die set it should have a guage. Or screw it into a die....
I have been to about 8 hardware stores. I don't believe its a common thread pattern. Going to try a nut/bolt specialty type store next. Thanks for suggestion.
will try fastnel. went to supply place found out its 7mm with some odd type metric pattern that they didn't carry nor were willing to order. had some jack of all trades sticking his nose into it so didn't get the other part of thread pattern. place was SUPER BUSY so I left. oh well.
