Cbreiter
Hi, I am looking at getting a new engine for my kart. I am from Canada, so harbor freight isn't a good option. Princess Auto is my main source. I am looking at two in particular.
http://www.princessauto.com/pal/en/Engines/65-HP-196cc-OHV-Gas-Engine/8088379.p
and
http://www.princessauto.com/pal/en/Engines/7-HP-208cc-OHV-Gas-Engine/8445405.p
My main question is, beyond stock form is there any huge advantage to getting the larger one? I am looking to upgrade, with a bigger carb, high flow air cleaner, header, and rocker arms, valve springs. My main concern is, will the aftermarket parts for clones fit the 7 hp ones?
I want to add some gear ratio to my kart, it currently has a 72 tooth rear gear, which is a blast, but I would like to upgrade it to a live rear axle, and get a bit more speed, but still be able to roast the tires.
and
Not quite; you need to look at what side of the crank the rope comes away from. If pulling the rope will spin the crank CW as viewed from the starter end, then you will have a standard engine (CCW PTO shaft rotation). If it spins the crank CCW (CW PTO rotation), then you have a reverse rotation engine....
