Craftsman Chipper Chopper Carburetor :D
dragos28
Trouble Maker
Bakersfield, CA
This might not be appropriate since its not a go cart, but you guys have always been more than helpful.
I have a chipper chopper that i picked up off CL a month ago.
Craftsman 5hp with a Tecumseh engine.
I went to the sellers house, extremely nice old man, poured some gas in the tank, first pull & the engine started up strong.
sold, $170
i bring it home, fill the tank up and chop up leaves and branches, it ran perfect.
well, i was done and put it away,
the next day there was a puddle of gas. I look at the carburetor and it was just dripping gas.
I tightened the screw that holds the bowl on but it just kept on leaking. problem is that i cannot find where it is leaking from..
so i take it to the local lawn mower repair shop..
the guy keeps it for 3 weeks!!
he says he took the carb apart, tried another carb but cannot get it to leak.
so i take it home, luckily he didn't charge me anything..
I decided to give it a closer look and as im inspecting it, the bolts that hold the carb to the engine are covered in dirt and grime..
that carb was NEVER removed... that dirt & grime was never disturbed.. how the hell can you remove a carb & not disturb the grime???
i'm thinking that he never even took it apart & just lied...
anyhow...
what would you guys recommend?
should i take it apart and see what i can find... or perhaps order a new carburetor?
fowler
Bullsbrook West Aus
Well he didn't charge u so it wouldn't bother me what he did
But the top bolt does appear to have been removed
See inside the threads are clean
The second is the idle screw proberbly
But it isn't required to remove it
It can't be that hard to find the leak
Did the guy fail to stop it leaking or couldn't find a leak
To find any leak on any machine just remember fluid is sung ect to gravity
So the highest point of the fluid stream is where the leak is
Clean the carb of dirt and oil
Fill With petrol let it flow
Find the leak
If it still alludes u
It can only be from a set few places
Remember in a non running state there is only fuel in the tank
The lines and the bowl
So check both ends of the line
Check the bowl
On my Tecumseh powered edger the stupid plastic elbow that connects the fuel line to the carb is cracked
The crack is in the inside where it steals to the carb
I just put 0.8lt it the tank and run it runs outta fuel
With is only a few min past how long the job lasts
dragos28
Trouble Maker
Bakersfield, CA
I'm holding strong that those bolts were not removed, the pictures do not show that well, but just holding them in between your fingers would have removed a great deal of the grime...
anyhow, i do believe that i can just take it apart and have a good look at it..
thank you for point out the point where the gas can drip from...
i'm hoping its just a simple gasket and hopefully the carb is not cracked...
firemanjim
Just kartin' around....
Houston Texas
:iagree::iagree: not to hard to get gunk up there and keep it from sealing all the way. While you are at it, put in a big inline fuel filter.... :thumbsup:
If the carb's peeing fuel all over the place, it's generally one of three potential problems:
1)The bowl gasket/O-ring. Seals between bowl rim and carb body.
2)Bowl nut gasket. Seals between the retainer nut/jet and the bowl, bottom of carb.
3)And this is the really common problem- the float/inlet needle and seat assembly. There is a float inside the carb bowl, not unlike the the float in your toilet. This regulates the amount of fuel available to the engine. When the level in the bowl drops, the float lowers the inlet needle off the seat and fuel is admitted into the bowl. When the fuel level in the bowl rises to the correct level, the float rises, pushing the inlet needle valve into it's seat, cutting off the fuel supply. Should there be any debris trapped between the needle and seat, a damaged float that's not floating, or a misadjustment of said float, the fuel will continue to be admitted. The bowl will then overfill, and the excess fuel has to go somewhere. It will find its way out through the main nozzle into the engine, and/or out through the throat of the carb, and/or out through the bowl's atmospheric vent orifice.
When such flooding occurs, you not only need to sort out the obvious issue, but also examine your oil closely. Should excess fuel find its way into the engine (and it nearly always does) it will seep into the crankcase and contaminate the engine oil. Thinned out, the oil loses its lubricity and your engine will not last very long at all. The big hints: if all of a sudden the oil level is too high; if it smells like gasoline; if, rubbed between your fingers, feels thin. If these conditions exist or if you have ANY doubts at all, change your oil immediately.
Me, I would be furious with the small engine shop. To someone who has ANY idea what they are doing (no insult to you, this guy is supposed to be a professional), this is such an incredibly simple thing. I'd hate to see what the guy would have done with the snowblower I just repaired for a customer- exhaust valve was hanging, just short of completely closing. Caused just enough compression loss to all but refuse to start. YOUR guy probably would have kept it a year and then condemned the engine. And for the record- I'm a painter. I do the OPE repairs for extra cash...
And Jim's right- install a fuel filter!
dragos28
Trouble Maker
Bakersfield, CA
Thanks Doc!
I'll pick up an in-line filter and take the carb off, and apart.
I am pretty upset because he kept it for 3 weeks & didnt do squat..
I'll update with my findings..
zbuck
Ft. Wayne, IN
:wai: I am with dragos28, that carb may have been removed by some one else but not the last guy. Look a the intake gasket in the 1st picture, looks to me that it has never been off, unless he used the same gasket?
firemanjim
Houston Texas
Unfortunetly, some shops are shady... They reuse a gasket if its in good serviceable shape, and then charge you FIR A NEW ONE...... I dont think the dude did squat but let it sit cause he was in over his head with the work he already took in..... WHAT AN A§§.....
firemanjim
Houston Texas
Well he did charge a thing
So i wouldn't complain too much
Last year,before our company camping trip, I took my Indy kart to a lawn mower repair shop. Engine ran fine. The only thing it needed was the governor had to be reset (BnS). I had put on a thumb throttle at the wheel,and in the process of trying to get full throttle, I messed something up. Well,when I get there, I SPECIFICALLY tell him it MUST BE FIXED BY "xx"... He had like 3 weeks. He tells me, O hell, it wil be ready next friday...... Well the day before our trip, I went to pick it up. It was still in tbe same spot i left it.... OUTSIDE.... It sat in the rain a few times, warped/shrank seat cover,started rusting(fresh painted frame SCRATCHED by who knows what..... Then the kicker..... It was not fixed... AND he WANTED to charge me storage fee cause I didnt come for it the friday he said it would be fixed..... WHAT??? I told him O H€££ NO! He "offered" to call the cops,thinking he was gonna scare me. Told him go ahead..... Well, I know ALL THE OFFICERS..... LOL They told him he was looking at charges, if I felt like pushing it.... guess what? My kart was.miraculously fixed in about 10 minutes, while me n the cops laughed,secretly, watched. He apologized for the "mis understanding" and said no charge..., well duhhh
Shortly after that, I bought a small engine manual and have said to heck with small repair shops. In Houston, the ONLY place to go is Discount Go Karts of Texas. Yes, blaz,a forum member, works there. Makes no difference..... I have been dealing with the owner since he had the kart track and putt putt.... That man is a master kart mechanic, honest, and courteous.... He wont sell you something you dont need, and will talk you out of a bad plan even if it costs him profit. His is the ONLY place I can walk into hppy and walk out happy, WITHOUT an empty wallet....
I have said it before..... I CAN NOT STAND LIARS,THIEVES,AND CHEATERS.....
TTo be clear, I have done business with.that owner for almost 20 years now. Have NEVER EVER had ANY problems with them......and its not like we are friends because he dont know my name nor do I his. He does know my truck though and my face.
fowler
Bullsbrook West Aus
Yea we got bitten by the local bike shop
Sent in our kawa 360 farm quad to get a new belt, tyres, new pull string and a service while they're at it
I can do all that apart from tyres but why not get the "professionals" to do it
Save time we thought
Well get it back and pay the account
Next time we use it
Runs ok till warm
Runs like crap and sprays oil all over your left left
WTF
Turns out when they replaced the pull starter (yes they charged for a new starter for a broken string)
They had stripped out a bolt
Then drilled it in an angle and busted the houseing
So drilled further to heli coil it
Drilled though the case bolow oil level
So it doesn't leak but the crank case is under pressure when hit so it starts spraying oil
Take it back
Then they say it's been gone for 2 months (bike is used rarely)
It can't have been them
Even though they are the only bike shop in town
But denied it till the cows came home so we told them to shove it
But we still had to buy the parts off them
So $340 and a 4 week wait later we have a new side cover
Then I had to go back to work
So mum took the bike to the Husqvarna shop
He did a great job
So now he does all our small stuff now
And any parts he can't get we just use the web
dragos28
Trouble Maker
Bakersfield, CA
No... he kept it for 3 weeks...
had he been honest and said he doesnt have time to fix it or doesnt want to, i could have taken it elsewhere or taken a stab at fixing it myself...
but he had the audacity to say that he took it apart and tried everything, then he took another carb off another motor and tried that one too but it also leaked.. really... so then he replaced my carb... but if he took it apart, wouldnt there be evidence of it being handled...
anyhow.. i'll just learn to do my own repairs.. its not like these things are that complicated! lol...
:iagree: As long as you know how to use basic tools & have some understanding of how they work, small engines (or even big engines) aren't that difficult to repair...
