6.5 clone parts
mitch
any body got a preferred site for getting clone parts in Canada? I need a couple exhaust flanges.
Where abouts you located?
If anything you could always use the exhaust gasket to trace and cut out another in steel for the flange, Thats what I did for my bike's exhaust header.
Another Idea is, rob the flange off an used clone muffler. Should be able to get them at any lawnmower shop or potentially at a junkyard.
I do exactly what mckutzy suggests- I make my own. Use the gasket as a template if you have it. If not, I put a piece of masking tape or paper over the port, and burnish it with a slightly dirty finger.
You betcha! Another method I use if there's no studs or anything in the way, is to put a light coating of clean engine oil on the mating surface, then just press the gasket material to it for a second.
I find the oil method gets a bit tricky after the paper gets soaked. If it is a card board, it tends to work better cutting out before it rips prematurely.
There's an old panel beaters trick for finding air leaks in car door seals which will also work here & isn't quite as "messy" as oil; a very thin smear of grease :thumbsup:
I could see that working- kind of the same principle as applying bearing blue or prussian blue to machined surfaces to check fit.
I often use the oil, because I usually oil paper gaskets just prior to installation anyway. Not sure when/why I started doing that, but I do. If nothing else, it makes me feel better!
With oil the paper does stick to the surface of the material used, without glue, so that is one bonus.
