6.5 horsepower fuel pump
mitch
Ive got a 6.5 champion engine (honda clone) that cant be gravity fed due to the position of he motor. so i need to install a fuel pump Where should I mount it, I bought an aluminum pulse fuel pump. Ive been thinking I could mount it to the tube coming out of the valve cover leading to the air filter But I dont know ..
jjarkys
Springdale AR
I tried that and noticed a significant decrease in pump performance as compared to putting a fitting on the engine side of the valve cover separation.
fowler
Bullsbrook West Aus
What do u mean on the engine side of the valve cover separation
U mean in the head right next to the valve cover
Did u drill into the combustion chamber
Or did u put it in the crank case
Have u got pics of its location?
Hello and welcome.
Not alot of people have the champion motors. I definatly love mine, well worth the money. Well built and quite the strong motor aswell.
mitch
thanks for the feed back guys , mckutzy you cant beat a champion 90 $ for a motor that doesnt die cant go wrong.
jjarkys
Springdale AR
No. I put it in the valve cover but my valve cover is separated by a baffle and valve. As I assume most are. I used the existing hole which the op is referring to and I wasn't getting a strong enough pulse. Had to re-drill a new hole on the other side of the baffle. Which also appears to be the common thing to do.
zbuck
Ft. Wayne, IN
:wai: Do you still have the governor in this engine? If not, tap the gov. hole for your pulse. Where is your fuel tank located?
mitch
my valve cover is a two piece. did you take it apart to drill it and where did you drill on the valve cover, I took it apart yesterday and was thinking maybe on the bottom?
z buck my fuel tank is located right beside my engine have. great idea!
jjarkys
Springdale AR
I followed this tutorial. The last option they describe. It's a tight fit. Be careful when you drill the hole.
Thanks to another post on this site that lead me to AGK.
http://www.affordablegokarts.com/fuel-pump-setup.php
Looking at that tutorial & considering zbucks comment, the pump is mounted mere inches from the hole left by removing the governor arm...
zbuck
Ft. Wayne, IN
:wai:Fabroman is correct.That will give you a shorter pulse line and a stronger pulse signal. When using either Honda's/Clones on are racing karts, I just tap the gov. hole using an R drill and then tap with a 1/8 NTP. If the engine is still assembled, make sure to use plenty of grease on the bit and tap, that way you should not have any shavings getting in the crankcase. We also use a top plate to mount the fuel pump. When using a remote fuel pump, do not forget to install a check value in the fuel pickup line from the pump to the tank. As for the tank location, we mount ours under the steering wheel on the floor pan. Happy T-day everyone, be safe if traveling. Don B.
