GX140 modding
wall
Portugal
I was given a brand new GX140 with stock exhaust and filter, without clutch and tank.
I was wondering what could I mod in it for better performance and/or efficiency, starting from the simplest and cheapest.
My plan is to put it in an ATV and make it road-legal in Portugal.
wall
Portugal
But the engine will be modded anyway, be it for a kart, mini bike or atv.
Where should I start, beside removing the governor?
Everyone forgets about the air filter, & those that mention the air filter forget about the exhaust; consider them a package deal, the engine needs to breathe in as well as out...
You can also do relatively easy/cheap mods like porting the head all the way up to billet conrod & flywheel, heavy duty valve springs, GX160/200 valves... the list goes on, it all depends on how much money you want to spend
But does it reduce the engine's displacement?
The displacement is all in the pistion bore. The head is not going to change that. All the head does is change the compression, also then changing the HP
EDIT: A genuine GX160 head is 14cc, while a GX200 head is 22cc. Using the 160 head would therefor increase the compression
EDIT EDIT: Have a lok at THIS post. R_chez build up a GX200, so you could maybe follow his thread
Correct. A 140 & 160 head are almost identical, the ports & valves of the 160 are slightly larger by 2-3mm (this I know for a fact) & I think the same applies to a 120 head (but I could be wrong)...
wall
Portugal
And how many cubic centimeters does the GX140's head have? Is it interchangeable with GX160?
Before going to change the compression, Im gonna wager a guess that your going to need new jets for the change in comp and fuel octane.
How easy is it for you to get new jets? Ya there is drilling the old one.. but still, what if you mess up. Then what about a new filter. can you get those too, easily?
Did you not see the post directly above yours?
A 140 & 160 head are almost identical, the ports & valves of the 160 are slightly larger by 2-3mm (this I know for a fact)...
What part of that is unclear?
Yes, they're interchangable, I did it, I have 140 head with 160 valves on a 160 block but, I don't see the advantage of doing it the other way around...
A genuine GX160 head is 18cc nowadays (it WAS 14cc some years ago) just like the GX140 head (which I think have been identical, but I don't know for sure)
so imporving a "newer" gx160 with a gx140 head is possible, as well as improving a gx200 with any gx160 or gx140 head.
Mounting a BIGGER head (a gx200 on a gx140 for example) is a bad idea, you will loose most of your compression, maybe enough to even produce a good spark; therefor you'll loose most of your power.
that's why you want a smaller head.
So maybe there is a smaller (GX120 maybe?) that'll fit.
wall
Portugal
I was asking because if they did have the same volume and the GX160 already has bigger ports and valves I would just use a 160 head without porting mine.
Only if you use a larger carb. IMO, the inlet port of a GX160 head is inefficient with the standard carb. The size of a 160 inlet port is 432sq/mm where a 140 inlet is 322sq/mm; the cab on both engines is the same, with a throat size of 227sq/mm (17mm dia). The bigger the port size, the bigger the vortex created when the fuel exits the carb into the port, slowing down the fuel & reducing performance.
At the end of the day, the size of the port at the lowest point is the same so, if you really want to help the engine, either create a plug for the port or use a larger (19mm) carb...
wall
Portugal
So without buying new parts for now, should I just bore my carb, replace the air filter and try to find a cheap exhaust?
