Extreme front camber
danielzink
So.....
Do I just lower the shocks down in the mounts to help level it out ?
or....is this way it's supposed to be ?
Main passenger is gonna be a 60lb kid.
Thanks, Dan
Wow, that is extreme...
1. No, it shouldn't be like that but, it appears that's the way it was built (unless a PO changed the A arms (unlikely))
2. To achieve 0° camber, the A arms would need to be level, which is crazy close to bottoming out & (I think) beyond the suspension adjustments.
IMO, one of two things needs to happen:
1. The spindle bracket needs to be "adjusted" to suit the angle of the A arm or
2. The spindle itself needs to be "adjusted".
Option 1 is the more favourable of the two as option 2 will result in excessive negative KPI
NOTE: Either solution will result in the front being lowered by an inch or two
Start with the following: Move the lower coilover mounts to the furthest outboard mount hole. Adjust the coilover spring preload collar to its weakest setting.
Now, sit the little one in it, and see what it does. By hand, roll the machine back and forth a few times to allow the suspension to settle in, perhaps push down on the frontend a couple times and see where it rests.
If you're equipped with a welder, you can make up some new upper coilover mounts that will be vertically higher up (ie, measuring straight UP from the road surface).
Fabroman is correct in that the A-arms should be level with the road surface at ride height. Poor design notwithstanding, there should still be some up travel, although there may not be.
People often forget that in order for suspension to be particularly useful, down-travel at the wheel is just as important as up-travel (relative to static ride height).
Since there's a munchkin in there and high speed/performance is probably a non-issue, you could probably apply the following non-permanent solution: Affix some additional weight to the front end.
firemanjim
Just kartin' around....
Houston Texas
The lower end of the shock should be mounted in the hole closest to the tire. That will help some with the camber. You will still have issues though. When I was toolin on karts for spare change, I had a customer with exactly what you got. I replaced the shocks with real shocks of the same length. Then i cut off the spindle brackets and rewelded them with 0° camber. Couple months later, he had me cut off those brackets and put on a set with the king pin at 2°......
danielzink
The crazy thing is that these are brand new arms from BMI (just got em last week).
Dan
