Manco Project Engine/Clutch Guidance Needed!
Houdini
Richmond, VA
Hello all, I am pretty new to go karts and have just picked up a bit of a project. I bought the below Dingo roller and believe these Mancos always ran a torque converter, though I could be mistaken. Since I am starting with a blank canvas, is there any advice/guidance you could offer on whether I should stick with the TC route (figure a Comet 40 series) or a standard Centrifugal (I did read the sticky, but still unsure myself), and what kind of motor tends to be favored on something like this? Also, what kind of performance is safe to aim for on something like this? In the end I am looking for the best performance (speed and acceleration), but unfortunately am not exactly rolling in the dough at the moment. The area to be ridden is pretty flat, no hill climbs. Thanks in advance for any help, I really appreciate it!
Wow, almost 2 years & this is your first post? Saying "welcome to the forum" seems a bit redundant so welcome to posting :D
You are correct, as the Dingo was designed as an offroad kart, they came standard with a TAV2 torque converter attached to either a 5hp or 8hp B&S engine; IIRC the gear ratio was around 6:1
A 212cc Predator & a chinese TC will get you moving but, that's still gonna run you around $250; check craigslist & other local classifieds to see what you can find used...
Half-breeder
"Edit" button removed
I have to say Im probably one of the few ppl on here that has never owned one of those 'Dingo's'... but IMO... if you're not some giant guy(200lbs+), tryin to ride a go-kart... the HF212 motor (6.5 clone)is ideal for the majority of karts(especially beginners).
I 'would' recommend a TC... but if your budget is like mine a cent. clutch should do on flatter areas. If those are 16" wheels, Id recommend no less than a 7:1 ratio=24MPH. If you're looking to break traction id go no less than a 7.5:1=22MPH. A TC will allow you to run faster(top speed) and have the torque needed at take off/acceleration. If I had the $$$ Id run one... just remember youll need a JShaft if you run a TC(dont know if yours has one already).
Houdini
Richmond, VA
Yeah Fabroman, I was hopeful on something a couple years back, didn't happen, haha! $250 is doable, I was looking at the predator, but would you recommend something different if money wasn't as much an issue? It's one of those things where I don't want to wish I had done it completely differently 2 months down the rode!
Half-breeder, thank you for the input and advice! Please excuse my ignorance, but what does the JShaft look like? Can it me made/bought separately?
Half-breeder
JShaft(Jack-Shaft) are basically a keyed bar(normally 3/4", 6"-10" long) that attach either the driven(of a TC) or another gear to reciprocate/rotate along w/ another gear, to create the desired gear ratio. There are 100's/1000's ways to set up a JShaft. Alot has to do w/ clearance and gear/motor plate placement.
The good thing about go-karts is there are NO set rules!!! If it lines up, doesnt bind, and spins true are bout the only unwritten rules for a kart(my build is PROOF of that). Ofcourse theres the rules of gravity/inertia/common sense... but you can tell those that ignore 'those' rules(check for road rash).:thumbsup:
You might want to take a look at this thread
Joshbfashiggity, is offering his Comet series 40 for sale; it's actually from a Dingo ;)
Maybe he doesn't need his original jackshaft anymore and you can get the whole setup;
then all you need is the engine.
But: according to that thread it's a 1" TC so you need something bigger than a predator 212.
I've never owned one either :D
Not necessarily, a tav2 has an integrarted jackshaft...
A series 40 usually is 1"...
If you go that route, you could look for a 9hp (minimum) engine...
Half-breeder
hmmm.... I dont believe you... I think youre lieing to me! I think you need to send me a COMPLETE setup here to me and let me put it on my kart to prove it!...lol
Ive never owned one so ty for correcting me... my bad!
usually yes.. but it's also available in 7/8" (40c driver) and 3/4" (44 /the ribbed one)
So, I thought maybe just add the numbers to be "more precise" ;)
A genuine honda?? In all seriousness, a HF Predator would be just fine for you
I put it in the post this morning. Let me know when you get it!
Houdini
Richmond, VA
Houdini
Richmond, VA
I apologize if this is a double post, not sure what happened to my last attempt. Looking at a generic TC kit on eBay (3/4" Tav2 with JShaft and 2 sprockets, 10 &12). That coupled with the 212 sound about right?
itsid, thanks for the link!
Scout
Nutjob
Indiana
If you don't need to have this on the road right away, I'd wait for the Black Friday sale at Harbor Freight, I believe the 212 Predators will be $99.
Houdini
Richmond, VA
Thanks for the heads up Scout, unfortunately I'll be out of town during their sale. I've got a 25% coupon, so it ends up being $10 more, thankfully I have one close by now!
Nice try :lolgoku:
Ok, I think I've got it! If I pair the below (I'm assuming Chinese knock-off) TC with the Predator 212 I should be set, correct?
Yep, that'll do it...
Thanks again all, I must say this has been about the friendliest and most willing to help forum group I have met!
...But, you haven't met us...
Just messin' with ya, I know what you mean. We're a pretty laid back bunch; we joke, we laugh but, most of all, we help, that's why we're here :thumbsup:
Houdini
Richmond, VA
Thanks again fabroman! I've only been to Australia once for about 3 weeks many years ago, and a little north of you it seems (Brisbane). I'll choose my words more carefully next time on having met or not :lolgoku:
All I know is that thankfully I often find much better help on forums such as this than from my friends/neighbors who claim to know everything about everything, haha!
I'm going through and freshening everything up first (cleaning, lubing etc..), but of course the project initiated Murphy's Law on me and I rounded one of the rear wheel nuts, this should be fun!
That's about 580 miles north of me; ironically, I'll be there this weekend...
That because people who claim to know "everything about everything" usually tend to know closer to nothing about nothing!
You usually find that, when you ask someone if they know what they're doing, the more confident the reply, the lower the chance that they actually do know what they're doing...
...but of course the project initiated Murphy's Law on me and I rounded one of the rear wheel nuts, this should be fun!
Obviously :lolgoku: You didn't think this was gonna be smooth sailing did you?
A pair of locking pliers or a single hex socket (depending on how badly rounded it is) should do the trick
danssoslow
Louisville, KY
If you can resist the urge, and if there is no need to fab around it, get the engine last. HF does so many promotional deals and sidewalk sales each year, you might find another opportunity to buy in below $100 before you will actually need the engine.
Houdini
Richmond, VA
Yeah, I probably won't buy anything until I can get these wheels off!! Got one lug nut off, but that wheel is rusted to the shaft, soaking in PB right now. Oh happy days!
