Engine quit
gallagher19
Fonthill, Ontario, Canada
Need some help here. My engine was running for about 10 minutes and it just died. Waited a few minutes, started it back up and ran for another 3 minutes and it died again. Now it won't start at all. Plug was black, cleaned it up and put back in and it still won't start. Fuel is full, oil is good, fuel filter is fine, yet it will not start. What could it be?
Checked the air filter? Have you checked the oil level? Since you have not indicated what type of engine you have, I am assuming there's a good chance you have a low-oil sensor.
Scout
Nutjob
Indiana
Check the gas cap, it might be sealing the tank and not letting the carb bowl fill.
But according to his initial post the spark plug was black,
so there's either too much gasoline... or if it was oil..
a piston ring might failed;
and it's missing compression now.
I would suggest not even try to start it, anymore!
If it's a piston ring that failed, you might ruin the engine more and more with trying to start it.
remove the spark plug and slowly turn the flywheel by hand;
listen carefully if there's a scratching sound, stop turning the engine over;
it needs to be repaired (cylinder head off, piston out, cylinder honed, piston rings refitted...etc.)
gallagher19
The plug was black but not wet. Crap, I hope you are wrong!!
...or it could simply be a fuel delivery issue; if it's a B&S L head (or flathead, whatever you want to call it...) with a suction carb (fuel tank under carb) it's possible the pump diphram is no longer working; a sure fire way to check is pour a teaspoon of fuel in the spark plug hole & try to start it...
