new here ...having issues getting kart to move foward
jboatman33
Total newbie here. just got a kart the other day. has a 5hp briggs. after doing some slightly aggressive driving today the kart barely will go forward. if i lift the rear the wheels spin ok. but with me in ot it barely moves. i know there are several things that could be wrong just wondering if any one has any suggestions as to how to troubleshoot and pinpoint what is wrong. i believe it has a torque converter. ive read through some other post but i would do better if there were more pictures. any help would be appreciated.
firemanjim
Just kartin' around....
Houston Texas
Post pic of what YOU have.... WELCOME to DIYGK! If you were riding it,and now it wont go, its one of 3 things.... You burnt up your clutch..... You burnt up the belt of your TC..... Or your TC needs some TLC,, post some pics of what you got so we can see what "we're" working with...
welcome..
one quick question; what is your toothcount on all the sprockets on your kart (start at the engine and follow the chain and list all;
if you don't know and do not want to count the teeth, provide good detailed pictures ;)
My first though is your TC belt is toast...
With you in the kart, does the engine simply rev or does it bog down? If it just revs, it's most likely the belt (or the clutch if it's a centrifugal clutch); if it bogs down, it's a weight/gearing issue but, since it was ok yesterday, I'm inclined to rule that out & put my money on a dead belt...
jboatman33
update w/ pics
took the cover off the clutch today and im pretty sure the thing is toast. take a look at these pics and see what you guys think.
also if you happen to be able to tell from the pics what kind of Comet this is that would be great! looks like the shoes on it are totally screwed. i dont know what they are supposed to look like so im not sure. the center piece has good lubrication and slides ok. i can see the clutch tighten inward when the engine is revved but there still seem to be a lot of slack in the belt so its not catching 100%. i supposed its also possible it has the wrong belt on it. when the cart was working, you would rev the engine and it would take a second for it to catch and it would catch with a bit of a jerk. i will stop rambling and let the pros chime in. thanks in advance!
https://plus.google.com/photos/1080...s/5944817011235921073?authkey=CM3jjO2cjbC9uAE
I'm sorry, that looks like you have a series 40 driven and a series 30 driver;
and to make things worse, a belt for another different TC (TC88)
So, the driver and driven need two different belts, you have neither of the two.
This cannot work (or at least not very well) :(
[EDIT]
you need either a new driver:
http://gokartsupply.com/4044seri.htm
OR a new driven:
http://gokartsupply.com/asymapp.htm
in both cases a new belt:
http://gokartsupply.com/tcbelts.htm
[EDIT II]
Oh wait.. the TC driver looks a little like series 30 and the driven like series 40...
so it might be a matching set, could you please confirm that?
jboatman33
what to do?
so if thats the case...what would be the most feasible option to make this thing work like its supposed to?
jboatman33
whoops did not read your edit there sorry. can you tell me how to tell which one is which model? would it be stamped some where or is there a certain characteristic to look for?
it's hard since the TC88 isn't available anymore and I can't find much info on what it should be.
AFAIK the TC88 belt is a symmetric 5/8 V-belt drive with 15° angles.
but you have the belt, so that's not a big help here ;)
if you look at your driver from the side both sheaves should be in the same angle, the series 30 driver has a 'straight' inner sheave (the engine side) it's not perfectly straight, but just 2.5° barely noticeable ;)
the driven should be 7" for the tc88 and 7-37/64" or larger (8+) for a series 40 in diameter.
