Need help kart wont move?
blackshuck
hey guys i got this kart for 80 bucks all i did was buy a a 17 tooth hilliard extreme duty clutch. i have a 60 tooth sprocket on the rear axle and the kart wont move.the engine works great by the way, the rear axle will spin great when its on blocks but when i put the kart on the pavement the clutch smokes a little bit and doesn't move at all. so just for the specs i have a 17 tooth clutch, 60 tooth sprocket and 18 inch tires and the motor is a 9 hp Honda .new at this and i have no clue if its a bad clutch or a gearing issue please help!IMG_0386.jpg
Half-breeder
"Edit" button removed
17T clutch... 60T axle= 3.53:1 ratio... on 18" wheels?!?! 'It's' no wonder why it wont move... you have the equivalent of an R/C car power, 'trying' to move your kart(at the wheel)!... you NEED to raise your ratio considerably... like a 10T clutch and 80T axle... or even better a TC and JS setup!
Just FYI... if you 'could' get that thing moving as it is now... youd be doing 55mph. THAT speed on a 'yard kart' is SUPER dangerous and I dont think anyone here would condone doing such speeds on something made to only 'maybe' go a top speed of 35-40ish, and 'that' is PUSHING the limits of gravity/inertia/and common sense... IMO.
fowler
Bullsbrook West Aus
yep
super high gear ratio
id go with the tc if u can afford it
u will be super impressed by the performance compared to a cent clutch
Sorry but, you bought the wrong clutch, you need a 10tooth.
Your current gearing is 3.5:1, that's almost half way to where it should be...
The reason the axle will spin easily with the back end raised is because there's no load on it; as soon as it hits the ground, it now has the karts weight & the weight of the driver on it...
There's a good chance the kart used to have a torque converter, which would fit with the large tyres & 60t axle sprocket.
You now have 2 choices:
1. Get a jackshaft setup to reduce the gearing, stick with the cent clutch & don't try climbing any hills (cost around $50) or
2. Replace the torque converter & everything will be good (cost around $350)
EDIT: ...& thoser two guys got in while I was typing that :lolgoku:
blackshuck
oh geez! yea i should have researched before i bought the clutch, so how hard is it to set up a TC or JS?
fowler
Bullsbrook West Aus
depends what u get
if it has a backing plate then its just bolt on
if its somthing like a comet 40series
then u must weld mounts to the kart frame
blackshuck
ok what about the jack shaft i have no clue how to set that up, do you have a link i could look at like for a reference?
I know a jackshaft may be the cheaper option but, it's not the best option, especially if you plan to go offroad or anywhere near hills
blackshuck
if i do get a TC do i have to do any mods to the rear end to move it up or down or anything?
You shouldn't need to...
Please note there is an EDIT button in the bottom right corner of your posts; please use it as opposed to creating multiple consecutive posts
Yep, that'll do just fine, all inclusive, just bolt it on & away you go...
Triple check the pitch on your axle sprocket first! The last thing you want is to set it up only to find you have a #35 axle sprocket...
fowler
Bullsbrook West Aus
yep thatll bolt on
as fabroman pointed out
check our existing chain pitch
and chck to see where u are going to put your axle sproket
ti get the drive from the tc to the axle there is a smaller sprocket on the back of the driven unit
so u are going to have to move the axle sprocket further into the frame
Landuse- thanks, It does seem when ever this jack shaft topics comes up your the man to refer my thread. once again thanks.
I dont know if it was talked about yet. Make sure all the sprockets and chain are aligned up. Make sure you have some wiggle room to do so aswell. If it cant move a bit other problems can arise.
Like above, if no movement, there will also be a chain tension issue, but can be mitigated by other means. like a wheel, sprocket or short chain; all depends on space.
