The quest for 65 MPH
mattgoesfast
As my name implies.....I wanna go fast. www.youtube.com/watch?v=cwqZXvOoEX4
The great thing about this hobby is how much technical learning there is to go along with achieving a goal as massive as 65. The current engine I have is a harbor freight 6.5 HP. With aftermarket parts......
  • Billet flywheel
  • billet connecting rod
  • bored out carburetor
  • new box stock exhaust
  • 18 lbs springs
  • air filter
I haven't the beast together yet but i plan to soon. I accompanied this purchase with a new sprocket hub and a pair of split bolt on teeth for the hub. One for torque one for speed. The torque is your standard 12-72 6:1 ratio. But I might of over done it with the speed. 14-55 4:1 ratio. I am basically asking at what point will I peak in my power band with the above parts with governor removed. The clutch is a max toque only a handful of hours use.
With just the listed parts, no other mods, you're not gonna get much out of it. For starters, all those hop-up parts & a stock exhaust? What's the logic behind that idea?
There's a lot more you can do to get more power, the majority of those parts only allow you to safely rev higher...
Scout
Nutjob
Indiana
And no cam? Thats the biggest power adder one could buy.
Hmm, yes & no; true, a cam will increase power a great deal but, it's best used with a few head mods too; without the head mods, you're just holding the cam back...
mattgoesfast
No it is a upgraded exhaust
Sorry I guess I worded that poorly its a small header with a RLV muffler on it.
mattgoesfast
Yeah just to be clear this is the exhaust that I bought for it. Its called box stock because of its allowance in certain racing classes. http://www.arcracing.com/servlet/the-453/Box-Stock-Project-ARC/Detail
The carburetor is jetted a bored out to suck more air and fuel in. I can also possibly port the head to. Definitely trying to find a lap valve kit. I might try to yank a mikuni carburetor off a Chinese quad. I know cams are important but I think I can get by on what I have...the exhaust.....I like it one because you can swap out the muffler, I have the RLV muffler on there now because I heard you want back pressure too.
No back pressure... yes it had been throughly beat into my head too. :mad2::mad2::mad2::2guns::2guns::2guns:
Unless your going to race this, just use a straight pipe (unless the noise is more of an issue), your going to need all the help you can get.
Not the back pressure for a four stroke engine debate again. Lol
:roflol:
YOU DON'T WANT BACK PRESSURE, IT WIIL ONLY HINDER THE ENGINE...
As for the bored & rejetted carb, the engine will only use what fuel it needs, the rest is wasted causing a rich mixture or flooding which will also hinder performance.
As the engine was only designed to run at a max RPM of 3600, the stock cam will peak at around 2500-3000rpm which won't give you a lot of top speed, you might get it to 5500rpm; with the correct cam, you can get 8000+rpm out of it, with a peak at around 6000, more than double that of a stock cam...
mattgoesfast
:roflol:
So basically a 90 degree bend three stage large exhaust header is much better. Could you point me in the right direction of a cam I know there are many out there. I have the springs so is there any other parts concerning the valve train besides the cam and the 18 lbs springs that I NEED to have upgraded? What do you mean by peak at 6000 but you can ultimately get 8000 RPM's? Are you talking about my power band peak? I am going to talk to a automotive teacher tomorrow at my school (I am in Information Technology) I am on the right track with my gear ratios. The speed one is my main concern....but is it really as easy as just bolting the plate sprockets on and off to have torque or speed or do other problems arise? Thanks again for all of your help and regards to the pictures one is clearly just the engine is the sprockets. That reduction scares me.
If you must call it a "power band peak" then, yes...
You may need to upgrade the pushrods & rockers, I'm not positive on that...
The engine on my kart (see the link in my sig) is a GX160 with all stock parts except the air filter & adaptor, exhaust & head; the air filter adaptor & exhaust (see pic below or the build thread for the exhaust) are both custom made. The head is off a GX140 (14cc) with GX160 valves & has been ported & polished.
Now, given that I haven't had an opportunity to really open it up yet, I have yet to hit the torque peak, it still wants to keep going when I back off the throttle & will break traction if I punch it hard enough.
I built it as a low end torque engine so top speed is strictly down to gearing (5:1). With a low end cam, I'm sure I'll get even more...
My buddy drove it once & his only comment was "I can't believe how much torque it's got..."
Back pressure is BAD, mmkay?
What's a clipper kart? I sincerely hope it's a race chassis, or you're planning on some serious re-engineering. 65MPH on a more-or-less factory fun kart or yard kart is just asking for trouble! They just aren't engineered for speeds like that.
I'm seriously doubting one could get that fast with the equipment your referring to, on 4 wheels, 2 you might be able to with some serious race parts. ( Ex. The bigger 390 or an animal with alky for starters)
