Newbie here with some questions.
Nightmare
Newbie
Hello,
I have been browsing these forums and finally decided to make an account. I say Hi to all!
I have a old Briggs and Stratton 5HP flathead, I think 1989, and I was wondering what I could do with it. I don't have pics, but I have numbers :)
Model: 130232
Type: 3017-03
Code: 89101307
If anyone would be kind enough to shed some light on this to me before I tear it apart and re-assemble it? (Yes, I have rebuilt engines before, just curious about this one.)
And, I have decided to put a 12T centrifugal clutch on the engine (Chain #35) and a 40T sprocket on the live axle, giving me a 3.33/1 gear ratio; with 14-17'' tires on it (IDK exactly, I'll check tomorrow), I have a feeling that this engine will not be able to power my cart; is that true? If you can please give me a good gear ratio for speed and torque?
My frame has yet to be built, I am making it in my welding class out of 1-1/4'' 18-20 Gauge steel; I will be doing a rear suspension, kind of like:
from the thread: http://www.diygokarts.com/vb/showthread.php?t=3231 I will be following most of what he did for the rear suspension, except I will space the shocks out more, any tips?
Hello,
Welcome to the forum
Model: 130232
Type: 3017-03
Code: 89101307
This may help...
Simple rule of thumb (as you probably already know) is
"If it ain't broke, don't fix it"​
Does the engine run ok? Being an '89, I would think so...
DOUBLE IT! You should be shooting for somewhere around 6:1, lower (meaning higher number) with large tyres
As you most likely saw from the end of that thread, the engine was mounted to the side of the frame. If you wish to mount your engine in the centre then, yes, you'll need to space the shocks farther apart...
Welcome to the forum!!
With that gearing (3.33:1) you are going to have major problems. Your kart won't move. You are going to have to get sprockets that give you a ratio of AT LEAST 6:1. With tyres the size you are mentioning, you might even have to go lower to 7:1.
Nightmare
Newbie
So, if I goto 6:1 and I want to keep my 12T clutch, I would need a 52T rear sprocket (if my calculations are correct)? Or would it just be better to just get a torque converter...
No, 52/12 = 4.33, which is still too high. If you want 6:1 with your 12T clutch, you are going to have to get a 72T axle sprocket. You divide the axle tooth count by the clutch tooth count to give you your gear ratio.
A TC is always better than a centrifugal clutch, but you will still need to have a ratio round 6:1. A TC can handle steeper gear ratios than a centrifugal clutch, but they are not the solution for bad gearing
Nightmare
Newbie
Also if I were to get the 94ss "cheater" cam, and an aluminum billet rod, would I be safe with the normal flywheel or should I get a billet one of those too?
My tires ARE 17'' my current sprocket has 54 teeth, and if I would change my clutch to 10T it only allows my gear ratio to be 5.4/1, so I am going to get a 10T clutch and a 62T sprocket, sound good for a 6.2/1 ratio?
Doing some digging, my old frame, steering, body, before I chopped it all up, was the same as this guys and my axle is the same, rims, tires, brake, sprocket.
Sorry for ALL the questions, but I may have more.
I have decided to scrap the suspension idea... Out of my budget...
Your calculations are incorrect, 6x12=72, not 52... :lolgoku:
After only 5 hours? Really?
It would be safer with the billet flywheel but, not necessary; it would also be the most expencive item in the equation...
Umm, with 17"tyres, you may want to go even lower on the gearing, somewhere around 70t
1. How can you tell, there's no mention of any specifics in that thread?
2. Is there a question in there?
I put that down to you're living up to your name... :D
I'm joking of course, that's why we're here... to answer all the noobs questions that is but, you have to put up with the jokes too :D
Depends... If you JUST get the new bumpstick and rod, feel free to run the factory flywheel. In and of itself, neither one of those mods will result in an insane peak RPM. Building a performance engine is a lot like fitting a jigsaw puzzle together- All the right pieces have to go together to get the big picture.
To build something particularly revvy, you'd have to also upgrade the valve springs, alter timing, improve carburetion, and a boost in compression probably wouldn't hurt either. By THAT point, you'd be pretty silly to still have that old iron 'wheel on there anyway...
Nightmare
Newbie
lol, it's fine. :) I know thats the same kart, because it matches EXACTLY to my old one. I am going to goto 6.2/1 ratio, I need new tires so I may goto 15-16''. I will get the 94ss cam, billet rod, and 20lbs springs soon.
