Need Help...clutch
viking1975
I have a dingo with fat rear tires and just mounted a 13 hp Honda power washing engine...purchased a 1" drive shaft clutch and burned it out in 15 minutes...what the heck should I put in to make my kart work...it was direct to a spur of I think 40...my chain is a #41...need help...can't find torque converter.. need help..would love to go direct again but maybe with another clutch...don't know what to do....any advise would be appreciated......:kewlsmiley::2guns::wai::cheers2::surrender::auto:
Welcome,
what's your gear ratio and exact tire diameter?
massive can be anything from say 15" up to 24" or something.
With a 13HP engine you need to have a 13HP+ rated clutch to not burn it which are rare from what I know,
so maybe that's the problem, maybe it's just the gear ratio...
so a little more details please and we also looove pictures ;)
If by
you mean the axle sprocket has 40 teeth & a 1" #40 clutch has 14 teeth then your problem is gearing. That equates to 2.8:1; my lightweight kart with 10" tyres runs 5:1; you see my point?
With large tyres, you need to be running around 7 or 8:1 &, since you might have trouble finding a 100+ tooth sprocket, I thing you need to throw a jackshaft on that puppy
