5 hp Tecumseh carb question
I have a 5hp Tecumseh OHH50 engine. I bought a new carb for it and it ran but had some problems. Anyway- long story short- I just pulled the bowl on it and it doesn't have a welsh plug in it. The original carb did and so have any on YouTube rebuild videos. Is it possible this carb doesn't need one?
Anyway-I can't put my hands on the recipient and I'm not sure exactly where I bought it (I'm thinking MFG Supply but could be repair clinic. ....). So. I'm thinking just get a good kit and maybe play with the old carb a bit (which has the welch plug but it's rusty- bad rusty!)
Thanks-
As a rule, Tecumseh carbs are temperamental by nature (from what I've heard)...
If the new carb is aftermarket (which it most likely is) the manufacturer may have done away with the welch plug as it was deemed "unnecessary".
What problems are you having with the new carb? It may be a simle fix...
Before I disassembled the motor- bad idle and then the primer bulb didn't work. The welch plug is at the bottom of the primer bulb well......but it did work before. ....the carb got flooded with oil and I was just going to shoot it with carb cleaner and compressed air- but I'm thinking about installing that welsh plug.
zbuck
Ft. Wayne, IN
:wai: On all the original tec carbs that I have worked on their are to welch plugs, one on the outside, primer area and one inside the bowl area. Like stated you probably bought an after market carb., Oregon, Stens or Rotary. which I have seen with only one welch plug on the outside none in the bowl area. Fabroman, is correct in stating they are sometimes tempermental. Depending on how new the engine is, its probably has a EPA carb. on it (no fuel adjustments) and they idle poorly but should have plenty of top end power, but with any kind of crap getting in the fuel bowl they run terrible. If it were me, I buy the correct carb kit for the original and strip it completely down and either boil it in lemon juice or find someone with a ultersonic cleaner to clean it and rebuilt it. Making sure to set the float correctly. There should be a spring on the float pin, to control float bounce, if so make sure it is installed right. If you go this route, you will have to buy a primer blub kit has they do not come in the carb. kit, there are two different primer kits used on techy carbs, make sure you get the right one.
:wai: On all the original tec carbs that I have worked on their are to welch plugs, one on the outside, primer area and one inside the bowl area. Like stated you probably bought an after market carb., Oregon, Stens or Rotary. which I have seen with only one welch plug on the outside none in the bowl area. Fabroman, is correct in stating they are sometimes tempermental. Depending on how new the engine is, its probably has a EPA carb. on it (no fuel adjustments) and they idle poorly but should have plenty of top end power, but with any kind of crap getting in the fuel bowl they run terrible. If it were me, I buy the correct carb kit for the original and strip it completely down and either boil it in lemon juice or find someone with a ultersonic cleaner to clean it and rebuilt it. Making sure to set the float correctly. There should be a spring on the float pin, to control float bounce, if so make sure it is installed right. If you go this route, you will have to buy a primer blub kit has they do not come in the carb. kit, there are two diffgymerent primer kits used on techy carbs, make sure you get the right one.
Yes that was the plan ( kinda ) I was going to get the most complete kit I could find but use everything but the welsh plug on the original carb. I'm boiling the crap out of it right now. I may buy 2 kits-IDK- it would be nice to have 2 working carbs and you, me, and Fab all agree these carbs are tempermental so it might be nice to have a spare on hand.
Yes- these carbs have no idle adjustment other than the throttle position.They have a pilot jet. I'm thinking that the only thing wrong with the new carb was it got filled with 30w oil. The motor was spitting air into the carb ( found cam off one tooth when I disassembled the motor ) and I got the motor partially disassembled and (embarrassed to admit this- but I installed the valve cover on backwards. .....sooooooo- that's why the carb filled with oil.
I was thinking they're 3.different primer bulbs- but I'll get the right one.
Thanks for the help!
zbuck
Ft. Wayne, IN
:oops: Lets not call it embarrassed. I call it a learning experience. An you get AAA credit for admitting to it. You may be right on the primer kits, but all these years that I have been working on them, I have only used two, one with a hole in it and one without the hole.
A guy at a lawnmower repair shop sold me one that looks like a B&S bulb but fit the carb. ....
