Solohopper
Just picked up this Kart today. Not much to look at yet, but I wanted to put something pics up so you guys can guide me along the way.
No major plans yet. I basically want to get it to run reliable and safely.
It runs and drives now, but it won't stop. So my first project will be a brake. it is currently set up for a band brake, but the band is no longer there. How effective are these band brakes? I was looking at buying the parts to renew it. But I am open to suggestions.
One of the basic things I will be doing is cleaning up the frame. It has a couple of bent tubes, some booger weld repairs and it rattles a lot. I'll will add a seat with cushion cause that metal HURTS. HAHA!!
The motor seems to run strong. It will need a new throttle cable, and I will relocate the kill switch to the steering column for easy access. But it ran strong and starts right up. The chain has not seen lube in a while and the clutch will probably need replacing shortly as well.
Of course there are all the other details........new front tires, checking the rear bearings, adjusting the steering, and so on. YOu know....the fun stuff.
I already had my oldest son out in the garage wrenching on it with me, and that is the ultimate goal of this kart. To teach my three boys a little mechanical skills.
SO here are some pics since I know everyone loves the pics. Even if it's of an older no name kart that needs a lot of work.
