chassis design and material
rish
india
hey i am building a gokart.. i know the basic design of a gokart but what i want to know is what are the basics one should know while designing it.. noreover what should be the chassis material considering my kart weighs around 100kgs
100kg is a monster kart; are you building a kart or a buggy?
The main points are:
1. keep everything as low as possible; this prevents excessive roll
2. keep the weight balanced, both side to side & front to back; bad balance will affect pretty much everything
2a. if possible, mount the engine centred in front of the rear axle
3. wheelbase:track ratio should be around 4:3
4. If you're too uncomfortable, it won't be fun...
That's just what I can think of off the top of my head; others will throw in more...
rish
india
track width has to be 80% of the wheelbase.. this is a competition rule... we would like to build the kart as light as we could but everythngs weighs upto 100 kg
That seems rather heavy, I don't think my kart weighs anywhere near that much...
Anyhoo, 1" round or square tube, thin wall (1.6mm, 1/16", 0.0625", 16 ga) will be fine
rish
india
see my minimum trackwidth has to be 50 inches and that makes wheelbase =40 inches atleast acc to rules..here is my weight division.. all are approx
chassis-12 kg
motor(bldc 48v 800w)= 9 kg
battery(48v 40ah)=30kg
brakes-7-10kg(disc)
steering-7-8 kg
solar panel(coz we are making hybrid)-5-7 kg
tyres-20 kg
:oops: What a difference a 0 makes, thanks :lolgoku:
Are you sure you don't have that around the wrong way? Track shouldn't be more than wheelbase...
chassis-12 kg
brakes-7-10kg(disc)
steering-7-8 kg
tyres-20 kg
Well, there's your problem; you didn't mention it was electric...
So, the weight of batteries & motor sound about right but, you may be a bit over on a few things:
-brakes-7-10kg(disc): what are you using, truck brakes? Mine weigh about 2-3kg
-steering-7-8 kg:Again, heavy equipment or are you including the front wheels?
rish
india
yeah sorry my fault there... wheelbse is 50 inches and trackwidth is 40 inches... fabromann i have seen your kart and it has a rectangular chassis.. i wish to make a chassis of this kind
THE INTERCEPTOR
The Important Part is getting a 50:50 ratio in left:right segment.
The front:rearcan go upto 40:60.
Are u using Round or rectangular tubes?Mainly What's your current choice for material?Mild Steel/Stainless steel/something else?
rish
india
can i get a brief calculation or logic as to how you calculated that it should be 16 gauge?
rish
india
yeah that i know.. my question is how to know the outer dia of tubing and the gauge thickness of tubing/? any formulae?
Pick an OD, then pick a thickness. It is manufactured in many styles, should be available from dealers almost anywhere.
Where are you located, fill in your profile so we can help you better.
rish
india
i am located in delhi india.... od means?? i intend to make my own chassis and not buy it from a dealer.. have to make a kart for a competition
Ok, good. There is a few Indian folks who post on here.
You might be able to buy/trade/barter steel from a scrap or metal dealer for what you need.
Depending on your budget, if you buy the metal at a scrap dealer, look for some motorcycle or scooter parts, like brakes and tires/wheels.
Also what kind of tools/ welder do you have available?
rish
india
i have tig welding available.. my question still stands
1) HOW TO CALCULATE OD FOR KART FRAME
2)HOW TO CALCULATE GAUGE for FRAME
i need formulaes so that i can verify that a given material with given specification can take the load of the kart
There's no magic formula, the only thing to remember is thicker wall material will make the frame heavier but, not necessarily stronger.
It all comes down to what design you use & availability of materials as to what you use; if you have a design in mind, post it or a sketch & we'll help you decide...
