Dual Clutch Drive?
SpiderSpartan
Cincinnati, Ohio
Bare with me while I get a little crazy here. I just picked up a little old Manco cart and have been thinking about some upgrades I'd like to do to it. It has a single wheel drive on the left rear wheel, with the right rear being a dead axle. It's a blast on the road, but I'm afraid the neighbors will soon tire of me zipping up and down the street and this thing will not pull me around the yard. The single wheel drive spins too much. So I'm thinking get a live axle, but that will pretty much ruin my fun on pavement. So maybe a differential, but I've heard those can be worthless off road too.
Now I start thinking, "Hey, what if I ran the engine to a jack shaft with a clutch on either end?" That way I get torque on both wheels, but they can also spin independently for better control. Am I out of my mind? Anyone else ever think of a setup like this?
mymumisaman
uk
I've had the same idea but ran into some problems
1. Two clutches is twice the cost
2. Both will wear out quicker with the way you want to set it up
3. Both clutches need to engage and disengage at the same time
4. How will the brakes work? As you would need one on both the back wheels
5. Is there an easyer way to do what you want instead of a twin clutch system?
The last one did it for me why not make special hubs instead.
SpiderSpartan
Cincinnati, Ohio
So did you make these special hubs? Your first two points make sense.
3, they wouldn't necessarily have to engage at the same time equally, though that may cause extra wear, referring back to point 2.
4 along similar lines would not necessarily need brakes on both wheels. I think it'd be ok as long as you didn't ride the gas and brakes. Although it'd probably cause extra wear too.
A specialty hub crossed my mind too, but I'm not sure it'd be within my abilities to make, unless someone else makes such a thing. Turns out there is such a thing as a ratcheting hub, but it looks like they run $300:smiley_omg: I think I'd be better off with dual clutches.
With decent frontend geometry, a live axle rig will perform just fine on asphalt. Racers do it! I do not believe your dual clutch system will work. Why? because they will not "slip" when they are above engagement speed. Cornering will not improve over a live axle. All you will do is to add cost, weight, and complexity.
SpiderSpartan
Cincinnati, Ohio
Add a second engine to power the other side ok just kidding. On a more serious note I think you should try it and post results of a two clutch system.
:wai: Then I'll add a linkage to each throttle from the steering so it revs up the appropriate engine while turning. BRILLIANT!
I suppose you're right, and that this is what mymumisaman was trying to tell me to begin with.
Slightly off topic, I'm having some issues with the kart running without moving. By that I mean if I try to keep it stationary by holding the brakes without giving it gas it stalls. I just put it up on stands and it runs without giving it gas as long as I let the wheel spin. I suspect I know what this means, but wanted some experienced input. Thoughts?
And thanks for entertaining and gently correcting my crazy idea.:roflol:
Idle too high or clutch spring is worn
Fabroman is right. Putting the kart on stands, your tyres will always spin as there is no load. It is not the best way to check if the clutch is engaging
silver tucky, IN USA
If it's stalling when you put the brakes in while your in it your idle is to low or you med to tune your carb. In the air there isnt any resistance so it is going to spin regardless of idle.
If the idle was high why would it want to stall I would think the opposite. For my nitro trucks I would have to tune the carb. Not trying to start an argument just trying to get some knowledge.
Try stopping your car with the brakes and don't push the clutch in. The car stalls does it not. This is because the clutch is still engaged and the car is running, not because the cars idle was set too low
SpiderSpartan
Cincinnati, Ohio
Yeah, I was suspecting the clutch. If I don't get tied up at work tonight I'll play with the idle settings a little more and see if I can slow it down any more, but I think it's a clutch issue.
A centrifugal clutch has an engagement speed, governed by the spring tension. If the engine idle is set at or above the engagement speed, the clutch will engage & stall the engine when you try to stop.
On the other hand, if the spring is worn, the engagement speed will be lower so, at idle, the clutch will still be engaged &, again, stall the engine when you stop.
SpiderSpartan
Cincinnati, Ohio
I played with it a little, but wasn't able to get the clutch to ever fully disengage. I plan on tearing down the engine and doing a complete cleaning on the engine and carb over the weekend, so I'll post the results once that's done. Stay tuned...
SpiderSpartan
Cincinnati, Ohio
I cleaned the carb and the air filter, scraped the piston and the head, and replaced the spark plug. Put it all back together, threw it on stands, and adjusted the idle mixture and idle speed screws. The good news is it starts up a lot easier and more consistently now, but it still doesn't like to idle when I hit the brakes, pointing to a clutch issue. I actually noticed one of the shoes stuck engaged after stopping the engine one time. I poked it with a screw driver and got it to disengage. So now I'm wondering, is there a way to clean the clutch to prevent this sticking? It's the kind with what looks like coiled flat bars instead of round wire springs. Normally I would oil something like that, but I know getting oil on the bell is a no no. Can I take sand paper to it to remove any rust build up. I feel like I'm so close here.
If you can take off the drum, you can sand the glaze off the surface. That will help with contact.
SpiderSpartan
Cincinnati, Ohio
Hmm, just took the clutch apart and I suppose having 4 of those coil springs would certainly help the clutch work right.:roflol: Anyone know if you can find those at a hardware store? Can I order just those springs online it do I need a whole new clutch.
