Cylinder honing
tuneman
Hello I'm running a 6.5 honda clone and its about time for some new rings. I was wondering what grit bottle brush would work best for a small engine as this. Any help is greatly appreciated
zbuck
Ft. Wayne, IN
:wai: If you are calling a ball hone a bottle brush, then 320 grit, some people like to use a 400 grit for a light hone. Otherwise go with Russ2251 advice.
tuneman
Yes the original crosshatch is gone. Yes I meant flex hone I'm getting an ammco positive pressure hone too just in see the bore is not straight
Russ2251
AZUSA:Powered by LAWN-BOY
If bore is not 'straight', you're going to need more than honing.
Better off just replacing rings and be done with it...or replace engine for ~$99 and keep the old one as a spare.
Just my opinion.
zbuck
Ft. Wayne, IN
:) Flex hone and a ball hone are not the same, yes they are hones but two differnet types. I second what Russ2251 posted. Take your engine to a automotive/small engine machine shop and have them check it for taper and out roundness. Or if you know someone with a dial bore gauge and can read it, have them measure it.
