Bar stool racer question
1jimbeam
I just bought this bar stool racer at a motorcycle rally. Can anyone tell me what the motor is. Size or anything will help. The man I bought it from said he made it to run on asphalt and with a 150 lb person it will do 25-30 mph and close to 14,000 RPM. But what I want it to do is go extremely slow. I want it to putt at walking speed and top out at a slow jog. And to run in a pasture type setting at bike rallys. I think I will have to put larger tires on the rear if I need a larger back sprocket as this one is close to the ground.
1jimbeam
Also I weigh over 200 lbs. What is the smallest size motor that has an electric start?
1jimbeam
Ok here is the progress so far. I removed the 47 cc motor and installed a 97 cc motor from harbor freight. same results no power but probably good top end. (That I dont want). I have a 12t sprocket on the motor and a 60t on the axle and cannot go larger there. By the math of the rpm and tire circumference at 3600 rpm i will be doing 21mph. So I want to add the jackshaft. I have done the math and think I need to change the ratio from 5 to 25 and that would give me a top speed of 4.25 mph. That means the jackshaft has to have 60t sprocket and a 12t sprocket on it. A 12t at the motor clutch, a 60t at that side of jackshaft and then a
12t on the jackshaft to the 60t at the axle. Is this something that can be done with the jackshaft and is my math right.
Thanks,
Jim
Can I put a 60t sprocket and a 12t sprocket on a Jackshaft
Jim
You can put any sprockets you like on a jackshaft. You just have to ensure that they make gearing sense at the end of the day, and that you have enough space for the sprockets.
The way you have explained it, you will get a 25:1 gear ratio. You will be able to pull stumps wit all that torque
1jimbeam
Well,
here it is......I added the jackshaft. I dont have the exact numbers in front of me right now. But, I think I did a 12 tooth at the clutch and a 64 tooth at the Jackshaft, then a 12 at the jackshaft and a 70 tooth at the wheel. I changed the 10" tall, 4" wide tires to an 18" tall tire by 8" wide.
I really Like the way it looks. And the speed is right where I was hoping for. Im guessing around 5 mph top speed. Perfect for the campgrounds.
Jim
Sweet :thumbsup: Love the ape hangers
I only have two suggestions:
1. Put a guard over the jackshaft; that sprocket could be dangerous
2. Think about putting some larger wheels on the front to level it out a bit
1jimbeam
Thank you
Guard is a must, That is the next step.
No room for larger front tires.
I did level the stool for comfort.
Thanks,
Jim
