Torque Converter question
builder bob
MA
What are all of the parts in a torque converter? (I thought i had seen it on here awile ago but can't find it now)
could you specify the question?
builder bob
MA
so a torque converter is a centrifugal clutch that also tightens the belt, which is hooked to a pully which has a thingy on it? what is the peice on the outer side of the pully do?
I think this would be easier for you to wrap your head around, if the proper term was in use. CVT. Continuously Variable Transmission. Which is exactly what it is. both units operated by centrifugal force, and yes, the drive unit provides clutching duties.
Both units are capable of changing their effective diameter, and therefore the overall gear ratio. Since the ratio can continuously vary from it's engagement ratio to it's top speed ratio, it is a continuously variable transmission.
The drive unit reacts to engine speed. Once off idle, one sheave moves towards the other. This forces the belt into engagement, and ultimately onto larger effective pulleys.
On the driven side, the effective pulley diameter starts large, and as the one sheave moves away from the other, the effective diameter gets smaller.
Where does this fit in on an engine? Does it replace the clutch or does it fit onto a clutch?
You would choose to use one or the other. A centrifugal clutch is merely a clutch. Fixed gear ratio. A CVT has a built-in clutching function, so no additional clutch required. It is capable of a range of ratios, hence the name Continuaously Variable Transmission.
FWIW- I've seen a lot of this lately. Calling CVT a torque converter is not really the proper term, and leads to confusion.
Well that's comet's fault, it's officially called a "Torque Converter System" and named "Torque A Verter" (TAV)
So, if people refer to it as Torque Converter it's most likely because of it's name and description ;)
Maybe because (attention: car terminology)
a torque converter does exactly what this thing does; it is capable of providing the clutch and reducing the gear ratio about 3:1 (just like the tav 2.7:1 and a clutch)
for easy take off.
Yes it's a completely different system than the above, I know.
And I agree, seeing the TAV2 I do think CVT too,
but frankly I don't care much, if they want to call it shabbydodings, I'd even be fine with that;)
