Low budget DIY engine mods help
exenos
Project Nut
Not a whole lot as far as I know, it's not like a peerless where you can easily swap gear ratios. You might be able to find a manual clutch kit for it if it's a semi auto but that's about it.
DMCdesign
Master Apprentice
Uttrakhand, India
from what I have heard about scooter trannies and seen, the engine begins to lose momentum in the final gear. I had read somewhere that reinstallation of some parts allows max output at final gear, but I need an advice on it
SpeedBoy
Redneck
Plastic internals
Most of that info is irrelevant for a low budget time up
But what I gather from google
It's a 150ish cc 4 stroke scooter engine with a manual gear box made by Vespa
You can
Remove the muffler
Fit hi flow air filter (may require rejet)
Fit high compression piston
Run 98 fuel
Rebuild engine
U can do to this engine the same as any other
Just depends what's low budget for you
Some think $50 is nothing
For some its the max budget
One thing to remember is the gear box
It will only take so much before it'll lunch it's self everywhere
From a short vid on utube it appears the engine has plastic gears inside
For the generator maybe?
Anyhow plastic parts won't go well inside a tuned up engine
Why does it max out at 6000
Is it governed or is that redline
I know little of scooters
If u make it rev further that would be a good start
I fix small engines for people and I have noticed pretty much all new mowers even have a plastic cam shaft that wears out in them! not only that I have now been saving all of my steel cams because I can put weld on them and machine them for more lift where as plastic cams will break from to much pressure on the lob from the valve springs!
tuneman
You mean the lobes and all are plastic!? I've seen plastic gears on cams but not the whole thing
dnuccio
AZ
yep. open up a briggs 3.5-4.5 hp lawn mower engine. cams have plastic lobes and gear, with a metal rod running thru the center for rigidity.
i probably have one laying around here, if i find one ill post up a picture
fowler
Bullsbrook West Aus
wow
remind me never to buy a newer briggs
oh wait my parents just bought a briggs powered victa mower
dam it
it would be intresting to get hold of the test results they got
both why they decided to use plastic
and what the expected life spam is
just gotta do a valve set once a week and do a cam change out each time u chance the oil
I'm sorry is this the bajaj chetak engine you're talking about?
If so it's basically a clone of the vespa PX in the Motor should be a licensed clone of the PX150 Motor iirc.
You'll find a reasonable amount of tuning guides and parts for that more easily.
Basically if you want to gain speed you need say a Polini 177 cylinder kit, a dellorto 28 carb with a malossi membrane manifold and most likely the gears of a vespa cosa 200 to take the load hardened clutch springs are a good idea here too ;)
And as you might have guessed by now. that is expensive (even in italy)
Other than that and the improvement will be impalpable
(okay there are 166cc cylinder kits and 182cc kits but it makes no difference in the amount to spend)
SpeedBoy
Redneck
wow
dam it
They appear to be injection molded so its cheaper than milling steel and alot quicker, also there are some briggs with steel cams but they are the good engines that cost some 600$ and i have yet to find a Tecumseh that is newer and has a steel cam, it appears that going by the dates of engines have worked on that Tecumseh did the plastic cam first then briggs made theres the same only Tecumseh has a 3rd lob that retracts for the easy star thing.
Today I worked on a honda like a 500-700$ engine and it has a over head cam! never heard of it before and i though well they just mean OHV but no there is a cam over the piston! guess what its plastic.... and it gets worse! its belt driven! valves weret working and it was because the belt broke! and there is a hour meter on the thing it was on and it only had 2 hours of run time and the person i worked on it for confirmed that! :ack2:
About a week ago a engine came in that wasn't quiet seized but was close (run without oil) and i was thinking ok since the person doesnt care how long it lasts and just wants a little more use out of it i took the crank case apart to check and see if maybe it could be runnable again and the plastic cam was broke in half! it looks like one of the tappets was stuck up due to no lubrication and that it came down at just the right time and hit the lob on its side and busted the cam in half....
So point to prove the plastic stuff does work just not as good as the steel ones....
