Lost in gearometry
Hi,
yet again another thread with a gearing issue... why not ;)
Basic infos:
GX200 clone (3600 rpm unmodified)
I got me a series 30 TC (12T #35)
As far as the general info tells, I need to have about 6:1 ratio from engine to wheels.
Allright, that means 12T on clutch (not TC) and 72T on wheel sprocket, right?
Now, the TC reduces by 2.3:1 iirc;
so am I right to assume that I should end up with something like a 31 or 32T rear sprocket on my axle?
And if so, where could I find a sprocket that small (smallest I can find ist 52T right now)
OR the other way around, take that 52T axle sprocket and add a 20T sprocket on the jackshaft, right?
But again.. I cannot seem to find a sprocket with that or close to that size anywhere near.
(that one is available on ebay within the US but not in Europe obviously, and shipping costs twice up to three times as much as the sprocket unfortunately)
Am I missing something important?
Or should I just swap the TC's sprocket to the #428 more commonly used in europe?
Thanks for your help
IIRC, most run around 6:1 gearing with a CVT but, I guess you could go a bit taller. However, my understanding is that, the higher you go, the more you risk premature belt wear
No-That reduction ratio is the "low" ratio, applied at the CVT's point of engagement (starting from a stop). As you accelerate, the ratio decreases past 1:1, and finally topping out at a 0.9:1 overdrive.
For basic calculation purposes, assign a 1:1 factor to the CVT- this nullifies it in the equation, and you're back to 6:1 overall (12/72). If you wish to factor in the overdrive, then you want to multiply the overall redux ratio by the overdrive, 0.9:1, leaving you with 5.4:1. To do that with a 12T drive sprocket, you'd need a 65T axle sprocket.
Getting back to the engagement ratio, having a 6:1 overall redux ratio with that CVT would result in an engagement ratio of 13.8:1 (6x2.3), but again, that's fro a standstill.
[EDIT]
@ Fabroman,
Yes, that what I was reading..
but I can't find any "matching numbers" on sprocket teeth,
so I was wondering if that gear ratio is meant to be "from jackshaft to axle only";
having a 72T sprocket on the axle no matter if I use a centrifugal clutch or a torque converter that itself is rated to be something around 2:1 in ratio assuming both have the same 12 teeth.
Or is there just a secret source for very small (~30T) axle and/or very large (~20T) jackshaft sprockets that I didn't found yet.
@toystory,
thank you, that's what I wanted to know..
so basically to build up some more speed eventually I can use a smaller (65T or maybe even smaller?) sprocket on the back and see how it goes but I'll be safe to assume a 72T will do.
I would not gear any taller that 5:1 with your TC. That means a 60T axle sprocket.
What size tyres are you thinking of using, because that will affect the way you gear your kart as well
Oh okay, that's a shame, I was hoping I end up having a "speed option" with a TC alone, otherwise I could have gotten me a centrifugal clutch for a fraction of the cost.
But that'll have to do. 50 kmph isn't too bad at all.
I don't know exactly what tires I'm going to get, but they'll be in the 13-14" diameter range.
that is 8" rims with whatever comes along that fits into the carbody ;)
they must not be taller than 14" as far as I can tell from my digital model.
As long as I cannot start to fabricate I thought I could at least start to buy some parts.
Now I know that I need to ask you first ;)
If you are using 14" tyres, then you definately cannot go higher than 5:1.
To get different size sprockets, I just went to my local industrial supplier which sells things like bearings, chain, etc. They had all sizes and types of sprockets. I use this on my minibike. I just had to have a keyway cut.
My daughters kart has 13" tyres on 6" rims; I could be wrong but, I think you'll have trouble finding 13-14" tyres to fit 8" rims
See, mine (meadler.de) doesn't ;)
I can get a lot of different sprockets in different sizes but none fits a type 35 chain.
All have to be machined to fit a 5/8 shaft (and of course have the keyway cut)
But if you think I cannot go higher than 5:1 anyways then I can just grab an off the shelf 60 or 65T Kart sprocket, that's available even at german kart shops ;)
Thank you, I will definitely start with either a 60 or a 65T sprocket (depends on wich is easier/cheaper to get) If that's not accelerating properly I can get a 72T sprocket (that's the easiest to find around here)
The bad news is, that I strongly believe the boys will not be too happy about that (best case) 50kmph limit.
So eventually I will have to ask for some advice on how to gently and safely improve the engine to about 5 to 5.5k rpm.
But that's another topic for another day ;)
[EDIT]
@Fabroman,
Not at all, those will be scooter wheels not kartwheels.
something like this (ebay #190823820123)
[EDIT]
@Fabroman,
You do realise that 50km/h seems like 100 when you are sitting 2 inches from the groung :D:D:D
I do, but with those wheels it's more like 3 inches :lolgoku:
No honestly I know, and as mentioned we will use narrower wheels on a heavier kart compared to a standard set up.
Thus cornering will be a pain and more speed is not really helping there.
But I don't need to tell you what testosterone can do to logic.
They saw that I have three rotax 125cc with ~42HP in my garage and they instantly started to drool.
Despite that it's not my racing kart and we cannot even afford one of those engines (about 2k each) they still went all crazy
He'll never know that we mounted on of his motors, come oooon, don't be a chicken..
Yeah, because that's what we need.. 40 horses pulling at an axle off a not professionally calculated nor welded kartframe with some serious dork pulling the trigger.
Anyways...
I'm fine with that but I wanted to let them know we have an option to speed this up.
