spicer transaxle
5horsebriggs
so I took one off my dads murry because he got a new mower and im going to turn the mower into a kart and I would like to use the spicer transmission, but I hear it only good up to 20mph max, why is this and how long will it last at spped of 35?
I know a lot more about Tecumseh-Peerless trannies than Spicer, but as a general statement-
Mower trannies aren't designed with speed in mind. The largest problem would appear to be lubrication. They tend to have grease in them from the factory, not gear oil. At higher speed, the grease is flung off the parts, leaving them unlubricated. Racers will modify trannies with oil seals and gaskets, and fill them with 80-98wt gear oil to solve the speed issue. Durability is another problem altogether. Some units just won't take the abuse.
zbuck
Ft. Wayne, IN
:thumbsup: Very well stated TS. By Spicer transmission, I assume the you mean transaxle? In any transaxle, whether it be Peerless/spicer their is a lot of mods that has to been done to even get to 20mph. Turning a mower in to a go-kart, their are a lot of safety factors to be considered also.
Good point zbuck- I was concentrating solely on the question, and didn't really consider the context.
To the OP- 35MPH on an otherwise factory stock lawn mower is a great way to meet your maker. They have a fairly high center of gravity, and a relatively narrow track. Adding to the instability is that pivoting front axle beam. In addition, braking is dismal at the rated 5MPH, never mind 35MPH. To top it off, the steering system on a stock mower is pathetic at best. They are notorious for play in the sector gear, which causes slop and unpredictability. Adding to the slop is low-rate rod ends.
Long story short- If you're aiming for 35MPH on a lawn tractor, you'd better re-engineer the whole thing properly. Or say hello to my buddy Darwin when you see him.
5horsebriggs
yea im lowing the center of gravity, just going to use a normal axle and im modifying the steering, o I think I should be ok? or is it still a no go
firemanjim
Just kartin' around....
Houston Texas
Just stick with a plain kart. Nothing to modify,safer being lower to ground, and well, you're just gonna have more fun on the kart. When you get older, have more fab skills,money, and a life insurance policy, you can tinker with the mower. Too much work to hit 30mph safely for me .
As long as you change the braking, steering, wheel bearings, center of gravity etc, you should be OK.
There are probably a few other things to change, and if you continue with this we will help you out.
You can maybe browse this forum as well
www.atltf.com
ak99
Queensland, Australia
I agree with the replies above, I was going down this same path then came to the conclusion it was actually going to be easier, cheaper and safer to build a new frame from scratch and use various parts from the ride on.
Mine still has a few small things to do - floor sheeting etc.
And find some shifter keys for the transaxle...but that's another story
I have attached a pic so you can see what I ended up with.
By the way, that's not me in the photo.....
www.atltf.com
To be perfectly fair, that may not even be the best place to look. ATLTF focuses more on off-roadability, larger tires, lifts, lockers, etc. For a true taste, hit up one of the forums dedicated to sanctioned lawn tractor racing.
FWIW, I am (slowly) building a racer- and I can tell you that so far, the ONLY original parts I have left are the frame (reinforced with 1" SHS tube) the dash (also reinforced similarly) and the hood. That's it!
zbuck
Ft. Wayne, IN
:wai:Again TS, you are spot on. If you still going forward with this project. Go to heymow.com, they may/may not answer your questions. Their is also a build section, where you can get some ideas on the safety factors. I build drag racing lawn tractors, for the time and money that are put into them, you could buy two rebuildable go-karts and still be money ahead.
zbuck
Ft. Wayne, IN
:thumbsup: Very nice job
Warning! If you go to that site- sandbag, but don't post. The moment they figure out that you're not building a dedicated racer for the express purpose of racing in nationally sanctioned events, they will hang, draw, quarter, and behead you. They will then likely set your remains ablaze and offer them up as a sacrifice to the mower gods whilst drinking watery American beer, and singing something about a Copperhead Road. Having peed out your flames, they'll ban you, your family, your dog, and anybody that's ever not publicly shunned you. Then, they'll ban you again, just on principle.
Yeah- they're a bit stiff over there.
So they are a bit stricts are they.....LOL
