gearing
z34dohc@hotmail.com
I have a motorsports 150 dune buggy, the motor recently went on it. I purchased a new 7hp motor for it with a 3/4" shaft. had it mounted and running , Heres my problem. The original motor spun at almost 7000 rpm, this one will only spin at 3600, any idea of what gear ratio i would have to use to get the transmission spinning at 7000 rpm, now i know some may say just buy a bigger motor however its not in my budget right now. I thought if i could get a gear drive to speed up the transmission to the speed it requires to change gears, that would be less expensive than buying another motor, thanks
Industrial motors are governed to 3600RPM. You are not going to get more RPM's out of it without spinning the crank faster. This can be achieved by removing the governor, getting billet flywheel and rod, as well as 18lbs valve springs. You might hit 7000 then.
Why do you need it to spin so fast? Gearing is not going to help you gain any more RPM out of your engine. It doesn't work that way. You can either gear high for more acceleration and less torque, or low for more torque and less acceleration
We are going to need a lot more info from you. What type of kart is it? Where will you be riding (onroad or offroad)? How tall are the tyres? ......etc
Oh....and :useless:
z34dohc@hotmail.com
Thanks for the reply, i dont wanna speed the motor rpms up, i wanted to see if there is a way i can keep the 3600 rpm from the motor, with changing the speed of the transmission, via gear and chains, this buggy has a 4 gear transmission and needs to spin higher than 3600 to change the gears and it would be off road, not extreme just for the kids on the trail. Here is a picture of a similar buggy and transmission.
these pictures are not of mine, however they are the buggy and the same transmission and clutch and variator setup, if i can get the variator to spin faster from the shaft of the new motor somehow, it will change the gears. Thanks
z34dohc@hotmail.com
Oh darn, well see what you can find and maybe i can figure something out, do you have a recommendation on a motor that will work for these, I will search as well. thanks
z34dohc@hotmail.com
can i ask why they cant be used, is it something to do with the shifting of the cvt, is it hard on this kinda of motor....or is it just the rpm. i have the room to move the motor around for a different set up.
z34dohc@hotmail.com
It lost power and didnt wanna start, I had it looked at before and it worked for a bit, then no go again, i just got to the point were i was done with fixing the same motor over again, In all honesty i should have done more research and checked into more options, and i will be the first to admit it. sometimes its better to start fresh, I got the new motor for a good price and like i said didnt do the research i should have.
z34dohc@hotmail.com
and the comet will just slide onto the transmission shaft i have now or does it come with the whole case. Sorry just not familiar with these things yet, however i am learning. thanks
They will just slide onto your engine. They are made up of a driver and driven (just like the one you have). You do get ones that are a contained unit on a backplate. They are all in one unit. Then you get ones that you have to make a jackshaft. If I were you I would get the self contained one. Like this
http://www.ebay.com/itm/Comet-TAV2-...ain-/320967164152?hash=item4abb2240f8&vxp=mtr
http://www.ebay.com/itm/3-4-GO-KART...her_Vehicle_Parts&hash=item53fa944f2c&vxp=mtr
http://www.bmikarts.com/Torque-Converter-for-35-Chain-34-Bore-TAV2-Replacement_p_2382.html
z34dohc@hotmail.com
OK thanks for the help, does the converter come with a sprocket, my axle gear has 2 chains and sprockets, as seen in the first picture of my buggy. Should i maybe be looking at a sled engine instead. Jeepers i have no idea now.
The TC comes with a sprocket. Usually a 10 or 12T. That will run to a sprocket on your axle.
Looking at your pic again, i don't think you have 2 sprockets and chains. That looks like a duplex chain. The chain is one unit but looks like a double chain.
Have a look at my triplex setup I once had. You can see the sprocket on the engine reduction box
You can get a sled engine if you like, but it might be more trouble to put in if you are not too sure of what you are doing. Using the engine you bought and a TC might be the easiest option for you
z34dohc@hotmail.com
yes it is a duplex chain, i am still trying to get a higher rpm to the trans without doing anything to the motor. a sled motor would take sometime however may be chaeper than an new motor that bolts right in. I also looked at the comet at a store yesturday and it comes with a 1" shaft not a 3/4" and there didnt appear to be a adapter with it, so........it almost looks like more work to make the comet fit.
Changing to an industrial engine opens a can of worms no matter how you try to go about it. If you cannot repair the original engine, you're probably best to source a similar replacement.
In industrial engine with a centrifugal clutch will be a performance disappointment in comparison to the original, unless you go to great lengths to compensate for it's shortcomings.
Also keep in mind that gearing directly affect torque. If you WERE to successfully double the engine speed going into the gearbox, you would cut the available torque in half. In addition, you'd have to figure a way to connect that engine to the gearbox.
Common clutches (such as the Comets, Hilliards, MaxTorques, etc) are widely available in 3/4"- you may have spotted a 1", but 3/4" is not only available, but more common.
z34dohc@hotmail.com
ok thanks for the reply, guess i am stuck with a motor that will have to be used for another application and a buggy that doesnt have a motor. Things happen. and thanks to all for the helpful information. Would anyone now of a cheaper motor replacement. I think a replacement is around $7-$800 for a complete motor,
