Finally.
Gopedude
Keller, Texas
Today was my lucky day. I FINALLY got my hands on a good kart.
Its a manco, two seater with a 6.5 hp Tecumseh. Got it for $100.
It doesnt run, the front tires are flat, brakes suck, has a centrifugal clutch that appears to function probably, but makes a bad noise when the kart is rolled.
The seller told me he got it to run on starting fluid for a short period of time. The frame is in good shape for the most part, and the engine is a little rusty. It does turn over, which is good. i plan on taking it apart tomorrow to inspect.
Now for the pics. It was dark when i took these, so ill get some better ones up tomorrow.
http://imgur.com/a/pKm3h
p.s. Thanks guys for directing me away from a wooden firey death trap :cheers2:
Gopedude
Keller, Texas
Good luck.. I really wanted to see that wooden gokart go through, though.
it was recieving too much hate.
You and maybe someone else, were the only people encouraging it.
i still have it, and dont know what to do with it. Tho, ive been kicking around the idea to use it as a trailer for the kart. idk.
J_Walker
Florida
eh don't worry about it. Maybe when I get around to it i'll build a super special wooden gokart - for kicks of course. in name of you... I'll name it. The DudeGope
Gopedude
Keller, Texas
Maybe you could use it to start a fire! :D
I am glad you got yourself a kart. We will help you through the process of getting everything running
Its difinitely a good fire starter.
Im glad too. I had to wait a month to get one, but at least it happened.
I guess a good first question is, can anyone identify the cart? (other than the fact that its a manco.)
Gopedude
Keller, Texas
Post some pics here. I cannot access whatever you have linked for us
Oops. My friend took the pics with his phone, thats why i had to put a link. Here are some. These pics are from the seller. I havent had the opportunity to take a good one.
  • 52BB72EE-201D-44D8-9846-03348CDCEE6E-3489-0000001F5993D309_zpse88d37ba.jpg
  • 52124337-EFC8-43B6-A0B3-9FF209892060-3489-0000001F5102E116_zps59e609ce.jpg
:wai: WOOHOO! it's steel & it was a steal, good for you :thumbsup: With a bit of help, you should have it running in no time...
I'm just glad you saw the error of your ways before you got hurt...
Nice kart. I will have to do a little looking though to see what model it is
EDIT: It looks a bit like a white fox
If it wasn't a 2 seater, I would've said dingo but, you may be onto something
It does. Engine is on the other side, and the one in the picture doesnt have a bumper/angled floorboard in the front.
Thanks! I think it was a good deal.
Engine on the right indicates a live axle :thumbsup:
Meh, all used karts have problems but, for what it is, you did good
Gopedude
Keller, Texas
Yep its a live axle which i like.
I dumped out the gas, put in new, cleaned the carb, checked the oil, put in a new gas line, but it would only start on starting fluid. Once it started, it would run until the fluid was burnt up (about 2 seconds)
Any suggestions? I can put some pics up, just tell me what you guys need.
Also, carb was pretty clean and the float was working properly.
DaiSan76
Nixa, MO
Is there air leaking between the carb and the intake manifold? If you don't have any vacuum it won't run.
Gopedude
Keller, Texas
i got it to start after spraying starting fluid once again, and it idled for about 10 seconds, then died. Found out the gas line i put in, was crimped and when i moved it, it completey snapped off. Also, the little gas that came out when it was crimped, looked disgusting, even though i just replaced it.
Im trying to figure out how to take the tank off. it just sits on top and has no bolts attached to it. once i get it off, i will wash it out with fresh gas and go through the carb one more time, but this time ill make sure i clean all the little passage ways.
