Brake Leak
jandj
Williamsburg, Va
Try these guys: http://www.strangeengineering.net/catalog/pdf/104.pdf
You want the B3377 rebuild kit .The B3341 pad should work, call 'em to make sure. If not there's a contact e-mail on the Kelsey Hayes site (http://kelseyhayesbrakes.com/) , ask them directly if the B3341 won't work. As for the pad being glued, it's an extra precaution most people using the Airheart setup use. In theory it's not needed as the pad can't go anywhere in the anvil. Vintage racers glue 'em in case they burn through a pad at a race meet, if it's glued it can't try to cock out of square in the anvil if it get's worn down.The other reason to glue 'em is it holds the pad in the correct "up and down" position if you need to install spacers between your caliper halfs to get the right clearance on the brake disc. As for what kind of glue, if you found yellow I'm guessing 3M weatherstrip adhesive (aka gorilla snot) was used. It'll work.
dreazoian
Los Angeles
Thanks! But one thing.. how do i order??? Do i do it over the phone?
jandj
Williamsburg, Va
Over the phone is the best way. Talking to an actual person lets you ask & answer any questions thereby greatly increasing the odds you get the right part!
dreazoian
Los Angeles
i talked to them, they dont have pads anymore. But one thing im wondering is, why are my pads both different? one is smaller and has 1 hole in it and the other is bigger and has the 2 holes like the one on the strangeengineering website.. :huh:
dreazoian
Los Angeles
Been out of town & away from the computer. Let me do some digging on that.
So i found the pad i needed in uk.. for 30 dollars! i looked around the forum and found someone who had the same caliper and was in need of the same pad and took an extra car brake pad and grinded it down to the size needed and drilled a hole in the pad where it was necessary and used that. so i will be trying out that idea and as for the other pad i have already ordered it.
