Champion carb problem????
Ya it does have a plastic float. When I took off the bowl, I checked the float movement It seemed fine for movement and not gritty or delayed. I didnt take it off when I changed the jet though.
The motor is a few years old, but very low hours on it. Basically new. I dont ride my bike that much, but a couple times a month I let it run for a bit, Allways keep it full of gas. Its still on the first oil I put in there, I just havent changed it cause I figured It didnt need it cause I dont ride it that much. I havent taken it apart as far as the motor case itself, most I took off was the fan cover to repaint it.
Ill try today and see whats happening with the float.
I got into a car accident last week, got struck pretty hard, so bending down is a bit of a task. Luckily I can jack the bike up on the lift. but I still gotta look underneath.
I have been feelin a bit better lately. Went out and took a look at the bowl and float. Float seems good. No leaks inside. Needle functions fine and no crap on tip.
I did pull out the plug and it was covered all in soot. I did look it up but didn't really understand what was said about it. It had a gap of .032 aprox. Some refferances try upwards of .045 for a hotter burn.
I also needed a new Oring for the bowl screw. So I'm off to get a new one now.
Any ideas on what's happening?
Just an up date....
So I went to home depot replace the O-ring for the carb bowl. It got sheared or some how cut, not a problem.
I cleaned the plug with a brass brush, lightly sanded the tip and electrode, also checked gap to about .032 with a gap tool.
The last little while I had been going to shows, so I had been moving and riding it a little more than usual. I noticed about a couple of weeks ago the motor had been weeping a bit of oil on the bottom of the crankcase. I havent changed the oil since I first put it in( didnt think it would be a big problem as I dont really use it that much), I figured I check it while I was there.
I just slightly cocked the fill cap/dipstick and the crankcase puked out gas/oil with some force all over the place. It was about a Liter and a half of gas/oil at least.
I siphoned out the rest that didnt spill out( OH man... that gas/oil mix tasted like crap).
I did some searching and a number of people have had this problem, most figure the petcock just allowing to fill at will. It seems a bit unreal, but I have forgot on most occasions to turn to the off position, not running the carb dry or draining the bowl.
With all this no other problems, no smoke, sputtering, no other real problem that is the stalling from being to lean on half cock position of the choke, when the throttle is gunned, than slowly pulled and then giver.
The only mods are what I have described above and the current jet is a #80 from honda.
Should I just refill and go, or do I need to "wash out" the crankcase with something?
Any help on this?
I hoped I haven't ruined this motor, I refilled the motor of oil and ran it for a while, it rode pretty good. I needed to go to a big show yesterday.
