Welding, hows it looking?
2or3wheels
Minneapolis Minnesota
how does these welds look?
modelengineer
Lord of the noise
Sydney, Australia
Get a chipping hammer and stiff wire brush. Hammer the crap out of the weld to remove the slag, and then brush away all the loose slag before you make the next weld. You can end up with slag inclusions (v. bad) in the weld if you don't do this.
Go slower, and more steady. Practice flat welds before you do corner welds. They are much easier.
newrider3
Colorado
Learn to run good "stringer" beads, meaning you just strike an arc and pull the rod along, before you move on to rod manipulation, and lap and t welds like that.
Scout
Nutjob
Indiana
Lay the material out so you are welding flat. Something like that I would prop it up and use clamps or magnets so it sits at a 45* and I can lay flat beads.
sayre315
Rupp enduro
Oklahoma
thank you Mr. Tyler
that auto darkening mask is soooooo amazing! best thing since the invintion of toilet paper
sayre315
Rupp enduro
Oklahoma
thanks alot guys!
hey
i have a queston for any of you guys that have this welder
the problem is the wire wont go through the cord
i un screwed that screw that puts pressure on the wire
then i tried pulling the wire through and it wasnt easy
Kenny_McCormic
Kartless....
Michigan Troll
how does my welding look
im using the HF 90 amp flux wire welder with the auto darkening mask
http://s276.photobucket.com/albums/kk10/sayre315_bucket/?action=view&current=sayrepic201.jpg
Better than mine! Looks great. Elaborated on you wire issue. I always just feed the first couple inches clamp down the roller and pull the trigger till it comes out of the gun. Its not gonna go through there easy by hand. your pushing a single strand steel wire down a plastic tube.
jr dragster T
Cold place
Check your wire tip and see if it's clogged. Sometimes if you get too close to the arc it will melt back to the tip. Can also check the rollar's and all. Seeing as I have so many tip's I'm not alway's too worried about reviving them. You can see one is a new tip and the other is a revived clogged tip. I'm not 100% sure if you can even remove the tip on those cheap welder's. Also it makes it easier to make the cable straight and to remove the wire tip. And it's always hard to pull out. As long as the wire feeder can push it through then your good.
sayre315
Rupp enduro
Oklahoma
ok, well
the tip is almost new, nothing wrong at all
yes tyler the tips can be taken off of these cheap welders :)
no it WONT spit any wire out at all
and i have tried every tension possible
jr dragster T
Cold place
Well then you have a odd probelem. Almost like the wire is sticking inside the feeder hose. Check everywhere on the machine. Sometimes it can bind up and you may not notice it.
