Any torque converter alternatives?
ross1998
Hey guys, I'm planning on buying a go kart for off road use. It will most likely be roll cage type with big wheels in back and small in the front( not sure how much inches yet). I am sure it will have a 12 horsepower engine. My problem is I'm only 15 and don't have money to buy a 40 series comet torque converte, because I will probobly all ready invest ~300 towards frame and motor and don't have another 200 for a nice torque converter. I've been told that a centrifugal clutch will accelerate slow, can't go up hills, and clutch will burn out fast using it off-road. Anyone have cheap alternatives for off-road use? My price range for the clutch will be ~50 dollars.
Thanks
ross1998
If you get a small dirtbike engine you'll have multiple gears. It's a bit more work to set up but, well worth it IMO
Haha I'm not really considered mechanically smart/expirenced and this will be my first gokart ( I've had dirtbike before but all I did to it was add gas and change oil :) ) so it would be alot harder for me to add dirtbike engine and do all the conversions to it. That's not really an option because will most likely be pretty expensive and lots of complicated work.
KartFab
Thanks
Get a job, ask all your neighbors to mow the lawn for a few weeks, or anything to earn some dinero. Save up $250 more, spend it on a 40 series TAV. Problem solved.
Thanks
You are going to have a problem getting any clutch for $50. Your 12HP engine is going to have a 1" shaft, and 1" bore centrifugal clutches are going for just over $100. You are never going to get a 1" clutch for less than that
A centrifugal clutch is not ideal for offroad, but if you gear it really low, you shouldn't have it slipping and burning up. You should have some good torque as well. A TC is the best though, because if you are going up hills you will have variable speed ratios, but with a centrifugal clutch you have only one ratio
Hey, you asked :lolgoku:
ross1998
Already do siding during the summer, but my dad gets my paycheck and deposits into savings account every month, he only let's me buy essential stuff with that money and doesn't feel go kart is useful, so I'm saving up for a car.
ross1998
Would rather get a 100 dollar clutch then 300 torque converter, for me if the centrifugal clutch geared very low rides up hills, drifts, and rides in mud, sand, snow, I'm good. Do you think it will be able to do the job? ( I'm okay with replacing the clutch every 6 months if I drive about an hour a week)
IMO I think you will be OK if you gear it low
Can you tell me what the gear ratio should be?
We will have to know what the diameter of your tyres are going to be, the weight of kart and driver, as well as how rough the off roading is going to be. I would probably say around 8 or 9:1, but it depends on all these factors listed.
You will never have as much fun or get realise the full potentiial of your kart with a centrifugal clutch, but you should be OK using one
ross1998
K thanks, I'm 5,11 and 145 pounds. I don't know the exact weight of my go kart but I know it's the Murray red one the originally comes with a 6.5 hp motor and it's a roll cage type kart, wheels will probobly be 14 in the back and 10 inches in the back. I'm mostly going to be on sand that has occasional small bumps and hills, will also be on forest paths sometimes.
Yeah, I would probably gear it low like 8 or 9:1. You will have to try it out and see how your kart performs with that gear ratio.
