I went out and started the motor with both jets(one after another). A #75 and a #80.
Both when on the run position of the carb choke, make the motor die when the throttle is gunned. With the stock air box thingy it ran when I gunned it.
So im guessing I still need to go up a few sizes on the jet, good thing I bought a few.
A few things I also noted...
When I took off the air intake adapter I made, the old carb to airbox gasket/seal thingy isnt flat. It is a piece of metal that is over-molded with some rubber to provide a seal. The adapter flange is flat(checked both with a straight edge).
So im guessing there is some more air entering that whats coming from the intake itself.
other than buying a new gasket seal,
Can I make a gasket out of cereal box or something the like and back it to the existing one or replace it with some new made ones?........ Edit:I did some looking and found a few vids and other sites referring to the old milk/cereal box gaskets and there good enough durability. Thin coat of oil and good to go. Im going to giver a try on this.
