11hp Tecumseh Throttle Linkage
dreazoian
Los Angeles
Just traded my pocket bike for a go kart with 11hp tecumseh. I have no clue as to how the throttle cable needs to be hooked up. Any help?
dreazoian
Los Angeles
And i also do need to buy a gas pedal but unsure as to how it is supposed to get hooked up. like bolting it on, getting it to press down smoothly, springing back and yea that stuff.
dreazoian
Los Angeles
Here's what I have ATM.
carter
you see that bit of wire that leads off somewhere on the top of your carb? follow that to it's origin, the governer should also be hooked into the thing you find. the thing at te ends of these wires is where you want the cable to go.
Blazkowiez
Kart Aficionado
Houston, Texas
You'll need to go to a kart shop or lawnmower shop and purchase a cable clamp, find a machine screw that will attach that to the linkage housing and then add a wire swivel running the cable through the flat piece and lock it down on the other side.
Basically you'll need to make your linkage "snap-back" to neutral or idle. You will be needing to perhaps take it off the engine as a first step and then add a spring. Usually when we've modified these to work we've had to disassemble, weld a piece on the back side then add a spring.
Do whatever is necessary just make sure there are no kinks or hangups... we want this to be safe and always return to neutral when the pedal is released.
If you don't understand some of the terminology do more research.
dreazoian
Los Angeles
Its not a wire, its like a thin rod. So i would need another rod?
dreazoian
Los Angeles
Also found this just now. Is it any help?
carter
There should be a thin rod from the top of your carb, to some form of strange looking mechanism(throttle linkage) and a thin rod from that to your governor, that is if an 11 and 10 horse tecumseh are anything alike.
dreazoian
Los Angeles
Okay so this is what i got planned so far from taking what you guys suggested it and using it to come up with a method of my own (and from what i see it can work). Im thinking of connecting a rod kit to my gas pedal (which im going to buy) and having the throttle cable run through it and then cross from the back of my seat and get clamped onto a small hole thats on the side of the engine. Then having the wire get connected to the governor arm/throttle arm, whatever you wanna call it and get secured in place with a wire swivel. And i will also be installing a strong return spring ofcourse. If you guys have any better suggestions or if you think this wouldnt work out, please tell me cause my ears are ALWAYS open to your thoughts.
dreazoian
Los Angeles
Don't hook it up like you show in the last picture. That's the governor and you're asking for trouble if you mess with it. Check out this thread:
http://www.diygokarts.com/vb/showthread.php?t=22061
i just looked at that its well explained but one problem, the red lever on that post is the throttle so when its up the throttle is fully open, mine for some reason that isnt the throttle it just moves up and down and does nothing unless i push it all the way down then it kills the engine.
