I parked the go kart about three months ago because of a messed up tire. Was running fine at that point. Forgot to run the carb dry, so when I replaced the messed up rim and tire, I cleaned the carb really well. Still wouldn't start. It would start off of carb cleaner sprayed directly in the air intake, but only for a split second. So I went with the basics. I bought a new carb for it and got a new spark plug. I have good spark, fuel is getting to the carb, but when I pull the spark plug, it is dry. I tried spraying carb cleaner and starting fluid through the carb and now it won't even try to start. Turns over like a champ, but just won't start. Any ideas? Oh, and it is a TAOTAO ATK-125A 125cc Wrangler style if that helps. Also, I checked the oil level cause I know some of these have a low oil shut off, but it has plenty of oil. Please help!!!
