Ratio question
BigDuke6
Using a 4 hp honda motor with restrictor plate and same rear tires.
Is there a difference between an 11 tooth clutch and a 12 tooth clutch, if you adjust the rear sprocket to maintain the same ratio.
Ground clearance for the 12 tooth using less teeth on rear sprocket is one. Are there any others? I'm really interested in torque/ acceleration area. race cart question :auto:
If I understand you correctly, you are asking is you change the axle sprocket to maintain ratio, does the clutch sprocket tooth count matter. The answer is no. Lets say you have a 10T clutch and 60T axle sprocket. This gives you a 6:1 ratio. You could get the same with a 12T and a 72T. The ratio will still be 6:1, so it doesn't matter what sprockets you use, as long as you end up with the desired ratio.
The general rule is that you don't really want to gear higher than 6:1 (ie. a smaller number). You will fry your clutch real fast doing this. If you need to gear real low, ground clearance can come into play, and you might need to use a jackshaft to get the gear reduction you need using small enough sprockets that don't drag on the ground.
With a 4HP engine, I would suggest gearing lower rather than higher.
You give the example of using a 11 and 12T. Toy keep the same ratio, using the 12T clutch you are going to need MORE teeth on the axle sprocket than if you were using the 11T clutch. You said LESS.
Post a pic or two of the kart. You didn't mention tyre diameter. The larger the tyre, the lower you should gear
BigDuke6
Thanks landuse, I did miss speak above, lack of sleep.
We use an 11 tooth clutch, 68 gear, and 11.5 inch high by 8.1 inch wide tire approx 35.11 circ. no tach in the car. I'll get some picts up this weekend. I put this in the photo vid area. with the incar I judge how close he comes to redlining the motor. On pavement we used the above setup and he would redline if he ran 2 consecutive perfect laps, rare that happens on a 1/10 mile track. http://www.youtube.com/watch?v=VllZFdAopFQ
