Good 2-stroke engines
JOMC7
Ontario
I'm thinking of making a "Drag" Kart and i'm thinking of having a 2 stroke. I have been researching on the internet and have not found much help. Any suggestions on who makes good 2 stroke engine
exenos
Project Nut
Its not so much about who makes a good 2 stroke engine, its more "what do you want ?".
Do you want a cvt? Then a snowmobile engine would be best. If you want to do clutch drops and bang through gears then a dirt bike engine would be the best.
If this is going to be a true straight line drag kart then a free air sled engine would be the best if you can do some tuning yourself. If you just want to do a slap on and go, then a large fan cooled sled engine or a dirt bike engine would be the next best bet.
Don't forget the simple stuff, too- there are 2-stroke OPE engines out there from lawnmowers and snowblowers that could be used, too- depends on what you have in mind.
exenos
Project Nut
I was going to mention those but didn't think it applied because he wants to make a drag kart.
JOMC7
Ontario
thanks for the help. I like the looks of the Yamaha kt100 but its a little expensive . don't think ill get what I want for much cheaper though.
exenos
Project Nut
Hey! Another ontario guy!
Sled or dirt bike engine can be found for cheap on kijiji and other classifieds. For a actual purpose built kart engine I'd just head over to the nearest track where they race karts and talk to some of the racers, they can probably point you in the right direction. Give Anderkart a pm if you want he's kinda the racing kart guru here.
EDIT: Hmm, funny note. Anderkart's name gets changed to Neanderthal in spell check :lolgoku:
JOMC7
Ontario
Either way, I hope you have some fabrication skills, and access to welders and such, as this won't likely be an easy engine install.
don't worry, my school has a welder that i have been practicing with.
