Honda Odyssey Sportbike engine Conversion Questions
frankysfree
Fort Worth, Texas
Oh and i dont think i mentioned that i bought a set of yamaha warrior atv front shocks. They are about twice the length and MUCH beefier so i think they will work when the front end comes down after a wheelie...
frankysfree
Fort Worth, Texas
Its not coming along as fast as id like because ive been swamped at the shop and its hard to find good help.
I should be doing more work on it in the next couple weeks so bare with me.
frankysfree
Fort Worth, Texas
Have not gotten much done due to spending ALL my time working on customer bikes. Im almost caught up to a point where i can spend some time on it though. Gonna try to get the cage done next week.
frankysfree
Fort Worth, Texas
If anyone wants to help a brother out, Chase Bank is giving away grants for small businesses and i could really use one for my shop. I need 250 votes to be qualified for a grant.
All you have to do is click the link, log in using facebook, search "Monkey Wrench Cycles" making sure the first letter of each word is capitalized, search city/state is Fort worth, Texas and hit vote. Takes less than a minute.
https://www.missionsmallbusiness.com/
frankysfree
Fort Worth, Texas
Havent updated in awhile so heres some pics of progress. Still got ALOT to do on the cage yet including alot of cross bracing but heres what i have so far:
I also scored a matching front set of the Duro Scorcher tires that are brand new for $30:wai:
frankysfree
Fort Worth, Texas
Its going together good. I decided to get rid of the stock ody front suspension and do A-Arm suspension in its place. Should have the new components by friday along with my new Jamar pedal assy.
I have lots of stock FL250 parts for sale now:D
frankysfree
Fort Worth, Texas
Franky, If you cut those brackets off that hold the upper shock I can use them. Those brackets are the newer models. The yellow fl250's bolted the bumper to the shock mount. The new Ody I just bought has all the newer parts but with older frame. I can use those brackets in the future if you cut them off.
Did you see the seat pan that I have on my new Ody I just got? The bumper on this one is trashed but it's not even bolter to the frame under the foot tub. It's to short for older style frame.
Do you have the old engine basket/cage? I need the CDI coil bracket and CDI holder as well.
I tryed to save the shock mount brackets for you but man they were tuff getting off. They had 9 spots welds on them and looked like swiss cheese after i took the spot weld cutter to them and to top it off the spot weld cutter broke a couple teeth so i had to improvise...
matoolis
east texas
I just got through reading through this whole thread and your build is looking awesome..can't wait to see it finished and ripping down the strip. Good luck!!!
frankysfree
Fort Worth, Texas
Thanks. Ive got pretty much all the parts i need for the frame itself just need to finish it up when i get the a-arms, rebuild the engine that i have, and fab a shifter. Shouldnt take TOOO long:D
frankysfree
Fort Worth, Texas
lol i understand that, what kind of shifter are you planning on doing?
Hand shifter like they do on the minibuggys. It will be a handle i pull back to upshift and push forward to downshift. It will only be for when im not racing though as i plan on putting an airshifter on so i can have full throttle upshifts:D
frictionmod
new to Honda Odyssey
hi fellas, im a hot rod builder who now has 3 spcl needs kids, and I ride this freak of nature also, min was built from a Honda odyssey its a single seat roll cage on wheels with a 13 hp motor on it now and that trans I see on all of them, looks like a snow mobile trans to me, anyway, not firmiliar with these yet so I need a little advice on doing a rear suspension on this thing before it makes us all shorter, can you possible point me in the direction of the parts and part list so I can get started? thanks..........
I would start a new thread of yor own and ask away. Welcome
