Briggs and Stratton 4hp wont start
MartinH
Hi, I am at a dead end and am looking for an idea. I have a Briggs and Stratton 4 HP engine which has been in a shed for 15 years. I cleaned it up. There is a spark. It started easily and ran for a few seconds but stopped and I cannot get it going again. Putting fuel in the cylinder has no effect. Has anyone had this experience? I cannot understand why it did run but then gave up. Thanks, Martin.
colorado
:welcome2:
have you checked the oil level? can you still crank it? it sounds like it might have seized up on you but from your description I can't quite tell
MartinH
Hi, Plenty of oil, turns over, seems to be compression, doesn't seem seized?
Recheck the spark from the lead, not the plug. The plug may be gummed/fouled up. Are you using fresh fuel? Stale fuel can devastate a carb & an engine
Check the timing key. It is a small piece of square metal (often aluminum) that indexes the flywheel to the crankshaft. If it shears, the timing will be off far enough to cause the engine not to run, even if everything else is perfect.
B.M.800
TheBeal.
Central PA
Clean the carb, use some thin wire to poke out all the small passages you can find.
I take a blow gun to carbs aswell to blow out the swill along with using the wire to poke out the passages. Works good.
MartinH
Hi, I did clean the carb though perhaps it could be done better. The thing is, if petrol direct into the cylinder won't start it, doesn't that mean it's not a fuel issue? I will probably swap carbs with my 2hp engine and see if that helps, and give it a real good clean while its off. Cheers, Martin.
B.M.800
TheBeal.
Central PA
Clean the carb again, I cleaned one and I thought I did a good job, but the engine wouldnt start, so back off again and claen again. Worked after 2 or 3 cleanings lol.
{EDIT} Oh wait you said it is getting fuel in the cylinder. Silly me.
This is a key point, which is why I did not suggest you re-clean the carb, and turned my attention to timing.
I think a compression test may be in order. The fact that it started, and now refuses to even with fuel and spark- has me looking elsewhere.
MartinH
Thanks for all the advice. I will tackle it again when I can find some time. Probably should throw it in the canal, but I don't like to be defeated!
MartinH
Hi, Happy to say that the engine is running nicely now. The key had sheared off when I looked again. I think the problem was I didn't tighten the starter clutch down hard enough on the flywheel. Had to make a new key out of a bit of scrap steel. It is so much easier to have a Magnetron ignition coil, no need to remove the flywheel and bother with points. Thanks for all your advice, Cheers, Martin.
Glad you got it running, but it looked OK in the pic you posted?
MartinH
Hi, Yes, not sure what happened there, the next time I took it apart the flywheel was in a different place and the key was in 2 bits. Perhaps the key sheared after the photo was taken or perhaps the flywheel just came to rest in the right place after the key broke?
