How to build a go kart (for beginners)
I've seen a band brake applied to the clutch (I do not like that idea). I've also seen drums attached to the drive wheel/and/or sprocket. Sometimes on the dead side.
Both rear wheels are on bearings.
Paddle/scrub brakes are a common setup for 1-wheelers.
redsox985
PA
I guess the caliper on the unused portion of the sprocket could work for a disc style set up.
redsox985
PA
I don't care, I just though some of it could be touched up for appearance.
EDIT: I just update the 1wd kart bit with the above info.
Well, if it were to get stickied or put somewhere else, I would imagine the most concise and complete version would be used. Meantime, they're both here...
redsox985
PA
TS, since you have power, would you mind assembling what you find to be the most complete mix of the two with your own thoughts inserted?
domikas12
hey all I wont to build a go kart metal go kart but I dont have wielder and I wont to build go kart for maeby $50 or smalest $ but i wont to build i live in village and i vont to burn out litil grass gokart can be not pawer full i am bulding first time hah i have samo karts but no motors an they are woden and i dont have motor . i have motor electrik but how i can regulate power i need cheap go kart with electric or gas engines thankas for helping
qtband
St. Louis, MO
Some 1WD karts use metal friction pads mounted on the frame via a bar. This is called a scrub brake. When the brake pedal is pushed the pads physically rub against the tires on both sides stopping the kart. (Unless it's raining...)
Generally, no. Two potential problems- one, the output shaft is likely tapered and standard driveline components don't fit that style of shaft. Second, it may not have a variable throttle. Generators' throttle/governor mechanisms are often set to run at one fixed speed.
Will these wheels work I'm trying to get some wheels so I can build the spindle with a lathe.www.harborfreight.com/10-inch-x-3-1-2-half-inch-pneumatic-tire-67465.html Will they also work for rear drive wheels? They also have larger ones of these so whatever setup; is it helpful to have like 10s in front and 13s in back? Thanks
These wheels generally are not suited to kart speeds. The bearings aren't high speed bearings that are required for speeds that you are going to be going at
TJ8
What if I pop the bearings out and make plastic or brass ones? Or more is there any way to make these wheels suitable?
machinist@large
West Michigan, 49331
Brass or plastic aren't any better (in a lot of ways, even worse). Harbor Freight wheels are one of the items I flat out won't waste my money on for anything, and yes, I shop there, too.
Harbor Freight is one of those stores where they have some OK items, some really great items, and some that aren't worth taking home even for free because they're just moving the disposal cost off on to you.
The topic has come up a couple of time over the last year or so; try using the search function in the parts forum. If I remember right, there was a short thread called sorceing wheels or HF wheels; something like that.
Give it a shot!!!:thumbsup:
TJ8
The Drivetrain (axle, sprocket, disc brake, wheels, and bearings)
The drivetrain is the most important part of the go kart, Its how you move and stop! According to your frame design you need an axle with a key way. A keyway (and key) is used to lock a component to a rotating shaft so the component will spin with the shaft, and not slip (toystory_4WD). Look at some parts and this will make more sense to you. You will now need to worry about your transmission. There are two main types, a clutch ($30), or a torque converter ($200). A centrifugal clutch is the most common because it is the cheapest and is simple to use. A clutch works like this: There are two parts to a clutch, an inside and outside drum. the inside drum is connected right to the PTO shaft (thing that sticks out of an engine ) and is loaded with springs. The outside drum is installed the same way but can rotate without the PTO shaft rotating. Now you might be thinking why do i need one? Without one, as soon as you start your engine (will be really hard to start because shaft cannot rotate) Your go kart will go without you pushing the gas. What a clutch does is it lets you have the engine running, without the kart moving. When you start your engine (on lowest throttle) the inside drum will rotate without the outside drum rotating. The out side drum has the sprocket for the chain on it, and the chain connects to the drive sprocket on you axle. When you give the engine throttle (pushing on the gas pedal) The inside drum expands and grips the outside drum and makes the chain move. When the RPM of the engine is increased the inside drum expands get it? It is kind of hard to explain how a clutch works without showing you what it looks like but just look it up on youtube, there are a lot of videos about it. A Torque Converter (TC) changes the gear ratio at all times so you get a lot more speed and acceleration and they are definately worth the money, but they are a little harder to understand and more complex to settup. Once again there are more detailed links for TC's and Clutches on other threads, but im just going over the basics. There is a cheaper option such as a 1 wheel drive kart. That means that instead of having an axle you bolt the sprocket to the wheel and bolt it to the side, so only that wheel moves. It is not as efficient but will save you money!
diagram of rear live axle:
http://www.willardssmallengines.com/...large/3987.jpg
So how does the one wheel drive work is this picture supposed to show it? I thought the sprocket was supposed to be connected to the wheel...
