Keep in mind that a 2 stroke requires TWO stages of compression. If the crankcase does not seal, it will not pressurize properly and either run like ca-ca, or not run at all. Recap- On the UP stroke, air/fuel mix is drawn into the crankcase. On the DOWN stroke, it's compressed and crammed through the transfer ports into the cylinder where it gets fully compressed on the following UP stroke. It could be the rings, too. A cylinder compression test is in order as well as a crankcase pressure test.
