thanks for the reply , unfortunately that is the only way the tav2 will fit in my frame with the clone block shape. I am looking for a 5 hp briggs because I think I will be able to mount the tav2 straight since the block won't be in the way. what do u guys think ? would the gas tank be in the way with a 5 hp briggs?
I was wondering about that.... so basically you're saying the back plate is hitting on the back side/ bottom edge, so you "clocked" it back that one hole? If so, you may very well have the same problem with a different engine; the hole pattern may change, but the hole orientation is usually the same.
You may have to shim the motor up vertically to gain the space you need, or grind a little off the back plate. As long as it's a
SMALL amount, only where you need to to get the bolts in the correct holes, grinding it shouldn't hurt a thing.
