Go Kart Brakes
racer454
If i was to use motorcycle hydraulic disk brakes on my go kart will it work? I dont want to end up spending $200 on go kart ones so i want to know if motorcycle ones will work
modelengineer
Lord of the noise
Sydney, Australia
Yes they'll work, but you'll need some sort of adapter or custom hub to mount the disc to the axle. Alternatively you could use the bike caliper on a kart disc.
The only problem I had was the bike master cylinder didn't displace enough fluid because I used flex lines which were about 2m long. They expanded *just* enough to mean that the standard rear master cylinder wouldn't apply the brakes. I used a motorbike caliper and a standard cheap trailer brake master cylinder. It worked perfectly.
My last build used a motorbike caliper and my current one does too :D I might even add a couple of bike ones to the front wheels of the current build, depending on how fast it turns out to be.
racer454
Thats true. But I think im better off buying a used pair of motorcycle then spending like $150 on bike ones
I got lucky, I found a full setup (master, hose, caliper & disc) from a GPX 250 for only $50 & it works too well!
To avoid the problem that modelengineer had, I used a cable to actuate the master which is mounted at the rear of the kart
Swabbster
Go on ebay and buy a hydraulic atv brakes there bout $50 and it comes with disc, caliper, line, master cylinder,
