alcohol injection?
jman98
has anyone done it? what all would it take to take a regular kart engine and run it on alcohol
jman98
yes thats what i meant. thanks for the answer. my next question is can i run methanol in an engine ive already put gas through? and where can i find the methanol fuel?
Yes you could mod/re-jet your carb to run methanol, but something you might not understand is this would not necessarily make any extra power on an otherwise stock ('regular kart') engine. You'd need higher compression and more advanced timing to get the full benefit of switching to methanol fuel.
The biggest advantage of methanol is greatly reduced combustion chamber temps compared to gasoline, and its this cooling effect of methanol that helps your engine survive longer (compared to gasoline) when running ultra-high compression and more radically advanced timing. Its that extra compression and timing thats actually making more power, not simply the alcohol by itself.
jman98
thanks clearing that up anderkart. thanks to the rest of you as well.
