Predator Engine Help
dreazoian
Los Angeles
Be worried. Anything interfering with throttle operation is not a good thing. Stuff like that leads to stuck throttles. You have a kill switch on your dash, or somewhere else you can reach easily? If not- install one.
Oh alright thanks for the heads up! And yea I got one under the steering wheel.
jamyers
Buffalo Gap, TX
Note that the Predator air filters are pretty much carp and don't actually filter out much dust. They will keep large rocks and bushes out, though...
An aftermarket or home-made filter (like mine) is much better - and won't interfere with your spring!
tundrabeagle3
Ca
Alright i did that and so far it looks to be good, heres a video of how it looks..
http://www.youtube.com/watch?v=TrS3AgeiyIQ
Just one thing, after i put the air filter back on, it touches the spring and pushes the spring VERY little, like half a cm. I still tested the arm and it still springs back fine, should i be worried or will it really do no effect?
I meant the bolt below that one that holds the back of the gas tank to the block. The hole that I made was still on the metal arm plate not on the gas tank itself sorry for the confusion. With the spring being lower it wont interfere with the stock airfilter.
dreazoian
Los Angeles
I ended up making a small adjustment and changed the spring to a thinner, but stronger one and it no longer touches the air filter.
dreazoian
Los Angeles
Yea im actually looking to buy a new air filter.. Ive found two but not sure which would be better. Maybe you can give your opinion..
This: http://www.affordablegokarts.com/mm5/merchant.mvc?Screen=PROD&Store_Code=A&Product_Code=AGK100-CE4245ST&Category_Code=
Or this: http://www.ombwarehouse.com/GX200-Clone-Air-Filter-Kit-w-Carburetor-Stud.html
jamyers
Buffalo Gap, TX
I like this one - the price couldn't be beat! :thumbsup:
For details, see my Yerf-dog build thread, post #22. :cheers2:
dreazoian
Los Angeles
I would get the uni filter one I have the k&n style on mine and it lets dirt in .
oh alright but would it fit on the predator without making any mods? And i always thought that with those air filters on, it will cover up the choke so i wont be able to access it. i would still be able to access it right?
dreazoian
Los Angeles
Yea it just bolts on, but will probably need rejet your main jet on the carb after. For the choke you could use a choke lever bracket like this on http://www.ombwarehouse.com/GX200-Clone-Air-Filter-Kit-w-Carburetor-Stud.html
if you want to maintain the choke lever. It is not necessary to have a choke lever but it makes it easier to put the choke on and off.
Alright thanks but one last question, lol sorry im still learning. what size jet would i need if i only put on an aftermarket air filter? would this be good, im thinking about getting this kit
http://www.ombwarehouse.com/Racing-Jet-Kit.html
Once again sorry for all these questions but youve been a really big help!:thumbsup:
EDIT: And i cant get the drill bits myself because my drill recently broke and can not get a new one anytime soon so im just gonna buy the jet.
tundrabeagle3
Ca
Yea that kit will work I haven't tried the gx140 e tube yet but I hear it adds more torque. I had the .36 jet in my old predator with the air filter and header and it worked great. :cheers2:
There is no guarantee that you will need to rejet at all. You have to let your engine tell you if it needs rejetting. Do the changes to the engine, and then do the spark plug test to see if you need to rejet or not. There is a chart of plug colours in the Helpful links sticky somewhere.
dreazoian
Los Angeles
Alright so after finally finishing all the work on my go kart and painting it, i ran into a minor problem that i dont know how to fix -.- After hooking up the throttle cable, i took it for a run and it ran great except for some reason when i press down the pedal, it doesnt open the throttle fully, it opens it like 3/4ths of the way. Im not sure as to how i need to fix that problem. If you need pics just ask cause i got a few.
dreazoian
Los Angeles
Here, i tried to get them the best i can without removing air filter box.
tundrabeagle3
Ca
I can't really see too much with the air filter but from what I can see it looks like you might have a little to much slack in the throttle cable.
tundrabeagle3
Ca
You just loosen the wire stop on the end of the throttle cable the pull the wire a little to remove the slack.
