Predator Engine Help
dreazoian
Los Angeles
Predator Engine Rev Limiter
I got a new predator 212cc engine yesterday and today i turned it on and let it idle for about an hour, turned it off then turned it on again and let it idle for another hour again to break it in. My first question is how long do i have to let it idle before i can actually drive at full throttle? and also i noticed that there is a screw that limits how much the throttle opens. Do i need to leave it like that because when i open the throttle all the way it doesnt seem like its really at full throttle and the screw limits it from opening anymore. Should i open the screw to give the throttle lever more room to open up or am i supposed to leave it. And here are a few pics of what im talking about..
dreazoian
Los Angeles
You can open the screw all the way. It will give you more RPM without doing any harm. You should also be good to go with using it at full throttle
Thanks alot, and also i noticed the throttle doesnt spring back so there was a small bolt which i loosened and it started to spring back.. is that good enough to leave it as is or would i still need to go ahead and install a new spring?
Yes, it is recommended to loosen that to get it to spring back.
jamyers
Buffalo Gap, TX
Nope, it just limits how hard the throttle can pull against the governor - more or less limits the top governed rpm. You can remove it with no ill effects. And yes, I'd recommend an additional return spring - 2 is just good insurance against a stuck wide open throttle.
dreazoian
Los Angeles
alright and all i need is just one single spring? or do i need to drill a new hole somewhere?
dreazoian
Los Angeles
Look on my Yerfdog build thread in my signature, I've got pics of how I modded mine
I looked at it and its simple and better way to do it, problem is i dont have a clue as to what kind of different springs there are.. i found a few in my garage but they are way too weak. I put them on in several different places but it doesnt manage to FULLY close the throttle. What kind of spring would be good? and did you have to drill a hole in your mufler shield? i cant seem to find anywhere that one end of the spring can go in on the shield
dreazoian
Los Angeles
I am not too sure how strong those are, but they should be good
Alright il go to home depot tomorrow and take a look at some other springs too and pick up the ones that i think would work best, but before i do, where would be the best place to attach the springs that would give the best throttle return with only one spring?
tundrabeagle3
Ca
Yea I used those springs before and they are good the smaller one is the one you will most likely use. I had one end of the spring on the arm and the other right across from it near the bolt on the back of the gas tank. I used a small drill bit to make a hole for the spring to hold on.
dreazoian
Los Angeles
you made the hole on the arm right?
tundrabeagle3
Ca
No I made the hole on the right of the bolt holding the back of the gas tank. The arm already has several holes.
dreazoian
Los Angeles
Alright i did that and so far it looks to be good, heres a video of how it looks..
http://www.youtube.com/watch?v=TrS3AgeiyIQ
Just one thing, after i put the air filter back on, it touches the spring and pushes the spring VERY little, like half a cm. I still tested the arm and it still springs back fine, should i be worried or will it really do no effect?
Be worried. Anything interfering with throttle operation is not a good thing. Stuff like that leads to stuck throttles. You have a kill switch on your dash, or somewhere else you can reach easily? If not- install one.
